TheMonolith2001 Posted August 26, 2014 Report Share Posted August 26, 2014 So I still haven't gotten around to fixing the noise of the plastic vibrating against the metal on my hatch because it really only happens at very loud volumes. I know the right way to do it but has anyone tried simply stuffing it full of old t-shirts or something to separate the plastic and metal? I have a whole garbage bag full of old shirts and stuff I was going to donate to goodwill but I figured it might be worth a shot because it is free? There is no window that goes up and down or anything so I could fill the entire thing if i wanted to and not just as a layer to separate the two. I am having trouble finding good pictures of what I am talking about, but there are some in these threads: http://thespeedfreaks.net/showthread.php?6561-Cheap-Sound-Deadening http://www.cherokeeforum.com/f46/1991-jeep-cherokee-build-2001-a-49861/index4/ So far I am leaning towards just a couple shirts in between the metal and plastic because this is probably going to absorb sound rather than reflect it right? Or maybe the plastic being there is enough if it becomes stiff under the extra pressure of the stuffing? It wouldn't be that hard to undo I guess if it sucked. Link to comment Share on other sites More sharing options...
Skullz Posted August 26, 2014 Report Share Posted August 26, 2014 Don't cheap out, just do it right and call it done. 01 Ford focus ZX3 Pioneer AVH-X491BHS PPI PC 4800.2 Morel Maximo 6.5" x2 Link to comment Share on other sites More sharing options...
TheMonolith2001 Posted August 26, 2014 Author Report Share Posted August 26, 2014 Yeeeeeeeah I know. It would only be temporary unless it actually worked. I was just curious. Link to comment Share on other sites More sharing options...
Pioneerchuck Posted August 27, 2014 Report Share Posted August 27, 2014 Technically anything to keep it from rattling would work but doing right the first time saves time and money. Link to comment Share on other sites More sharing options...
Noel989 Posted August 27, 2014 Report Share Posted August 27, 2014 Don't spend money now going the cheap way If you do in the long wrong you'll spend way more Start the right way now and as funds come up just add more Little by little Build Log - http://www.stevemead...-cruiser-el-pt/ Link to comment Share on other sites More sharing options...
aculous Posted August 27, 2014 Report Share Posted August 27, 2014 So heres an idea. Look into JUTE padding. Its what they use for thermal insulation, its a fiberous material but not ridiculous expensive and will deal with a lot of issues. So saw a guy did a install with GT Liquid-damp (GTMat is the company) and then use JUTE padding which worked pretty, well it looked like it did from the pics. (Dude was a texas SQ champ with a red dodge) You are not adding mass as with using MLV or some other sound deadner but its a start and you can put a couple layers of liquidamp on it to get a little more mass. a gallon of GT Liquid-damp is $50 and JUTE padding is anywhere from 40-60$ for 24 sq ft is the standard it looks like. OR what I would recomend is look at Raamaudio. For $160 you get butyl sound deadening and some closed cell foam. You would be spending a little more but its worth it since almost all of these are REALLY hard to remove. Think about a job that takes anywhere from 4-6 hours for just butyl application and then quadruple it (most likely) for having to take it off. Its a pain to get any of these products off. And the asphalt products are worse...in almost every way. Link to comment Share on other sites More sharing options...
REH Posted August 27, 2014 Report Share Posted August 27, 2014 So heres an idea. Look into JUTE padding. Its what they use for thermal insulation, its a fiberous material but not ridiculous expensive and will deal with a lot of issues. So saw a guy did a install with GT Liquid-damp (GTMat is the company) and then use JUTE padding which worked pretty, well it looked like it did from the pics. (Dude was a texas SQ champ with a red dodge) You are not adding mass as with using MLV or some other sound deadner but its a start and you can put a couple layers of liquidamp on it to get a little more mass. a gallon of GT Liquid-damp is $50 and JUTE padding is anywhere from 40-60$ for 24 sq ft is the standard it looks like. $90-110 for 24sq ft of this stuff you're talking about... He'd be better off getting some real sound deadening material for the same price range. Link to comment Share on other sites More sharing options...
MrSkippyJ Posted August 27, 2014 Report Share Posted August 27, 2014 do you want sound deadening or something to stop rattles. Kinda talking about 2 different things here. F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69 Link to comment Share on other sites More sharing options...
Karkov Posted August 27, 2014 Report Share Posted August 27, 2014 http://store.secondskinaudio.com/ 2007 Chevy Tahoe (SOLD) 12 ~ FI Audio X series 10" w/BP option 2 ~ DC Audio 5.0K @0.67 3 ~ DC Audio 5.0K @1.0 2 ~ PPI 3 way sets (not installed yet) 1 ~ RF T400-4, 1 ~ RF T600-2, 1 ~ RF T600-4 4 ~ CT Sounds 5.25" Strato comps (rear fill only) 1 ~ XS Power D4800 1 ~ XS Power D3400 8 ~ XS Power XP3000 160 stock alt, Mechman 370 Elite, 185 DC Power 320+ Sq. Ft. Sound Deadener Pioneer AVH-X5500BHS Youtube: https://www.youtube.com/user/knfjdkghjudfhsgkjdhf/videos?sort=dd&view=0&shelf_id=0 Link to comment Share on other sites More sharing options...
aculous Posted August 27, 2014 Report Share Posted August 27, 2014 So heres an idea. Look into JUTE padding. Its what they use for thermal insulation, its a fiberous material but not ridiculous expensive and will deal with a lot of issues. So saw a guy did a install with GT Liquid-damp (GTMat is the company) and then use JUTE padding which worked pretty, well it looked like it did from the pics. (Dude was a texas SQ champ with a red dodge) You are not adding mass as with using MLV or some other sound deadner but its a start and you can put a couple layers of liquidamp on it to get a little more mass. a gallon of GT Liquid-damp is $50 and JUTE padding is anywhere from 40-60$ for 24 sq ft is the standard it looks like. $90-110 for 24sq ft of this stuff you're talking about... He'd be better off getting some real sound deadening material for the same price range. That is real sound deadening material, do some research and I think you would find that out. Look inside a cadillac or any car other car, they typically use jute as a cheap alternative for sound and heat insulation. Its just cheaper then closed cell foam or butyl which is what a lot of people use. Some even use MLV which is not typical but it works. mass to lower resonant freq. and then something to break up sound waves. Link to comment Share on other sites More sharing options...
