Vht NightShade for Patriot Tail lights
I am considering tinting my tail lights. How many coats of spray should I use? I don't want crazy dark but nice middle of the road tint levels
Team MaxRetribution
Si Vis Pacem Parabellum
Use Rustoleom shade. Its much better. Then use automotive clearcoat, don't use any other. World of difference compared to VHT and regular clear.
Just do light coats until you're satisfied with the darkness. Everyone sprays down different thickness.
*06 330i - Sundern x12 - saz-3500*
*91 Foxbody V1 S-Trim Notch*
What makes Rustoleum a better product than VHT?? Lots of people seem to like vht with good results
Any other input would be appreciated
Team MaxRetribution
2010 Honda Civic LX / Deck: Kenwood DDX371 / Front Highs: Crescendo RTS-1 / Front Mids: Silver Flute 6.5's / 4 channel: DC Audio 90.4 / Sub: Fi 15in SP4v2 / Sub amp: Taramps HD 5000 / Power wire: Knukonceptz OFC 1/0 / Deadener: Audio Technix 60 mil / Batteries: XS Power D5100R / Rear bank: TBD / Alternator: Singer 240a hairpin
Just seems to work a little better. Few more dollars for a better product. Ive used both numerous times, just feel the rustoleom lays down better and looks better. Either or its your choice in the end.
I actually looked at that stuff but hadn't heard of it before and wasn't sure if it was worth the $$
Team MaxRetribution
It's worth it having them done with the smoked vyinl looks way better plus you can go back to stock if needed.
I actually like vht better then the rustoleum, I've always used vht with good results. I can't say the rustoleum is terrible but the one can I used seemed to splatter when applying the coats, the vht always is a very fine mist. As for amount of coats, just apply light coats till you get the darkness you want, if you plan on wet sanding to get a nice shiny/smooth finish apply an extra coat so the sanding doesn't remove to much and change your darkness.
Build log: Click
Feedback: http://www.stevemead...xbccp-feedback/
03 Chevy Blazer
- IPad Air 2
- ALPINE Head Unit
- 4 DC XL 18s
- 2 DC 3.5k
- ALPINE TYPE R 5.25 COMP
- 3 ALPINE TYPE R 6.5 COMPs
- DC 175.4
- DC HO Alt
- D3400
- 4 XP3000s
- KNU 0ga
- 60 SqFt Damp Pro
Lots more...
I used the VHT and believe I used 5 or 6 light coats. You can still see a slight red tint on my tai lights bc I didn't want them completely black. I also used 4 thin coats of glossifier then wet sanded the light with 2000 or 3000 iirc grit sand paper then buffed them with polishing compound. They look like they came stock like that in the car now.
2001 Saturn L200
-Sony MEX-BT4100P
FRONT STAGE:
- (4) Crescendo PWX 6
- Cadence XA250.2
SUB STAGE:
-Fi Audio BL 15 (Sealed Off)
-Crescendo BC2k
ELECTRICAL:
- Singer 240A alt
- XS Power D3400
- SkyHigh OFC power/speaker wire
- Big 3 with SkyHigh 0gauge
Build Log: Click Here
Scores: 146.5db @ 29hz Outlaw
It's 100% worth it. There is nothing better. The spray on's work well, but this looks nicer and is removable if need be.
  • Who's Online   0 Members, 0 Anonymous, 1780 Guests (See full list)
