LumberZach Posted September 1, 2014 Report Share Posted September 1, 2014 I'm looking to build a ported box tuned to 32hz for my 2 SA-8 v2's. The space I have to work with is 26"W x 15"D x 12"H. The subs will be getting power from a Hifonics BRX2000.1D. Looking to wire them at a 2ohm load, so each sub will be getting around 700W RMS each. I designed a box in the Torres Calculator, I just need someone to chime in and let me know if this box will be suitable. Thanks. Link to comment Share on other sites More sharing options...
Joe X Posted September 2, 2014 Report Share Posted September 2, 2014 More port area, have you seen the Sundown suggestion? I have also posted cutsheets for those many times. Link to comment Share on other sites More sharing options...
LumberZach Posted September 3, 2014 Author Report Share Posted September 3, 2014 More port area, have you seen the Sundown suggestion? I have also posted cutsheets for those many times. Do you have one that will fit in the space I have? Link to comment Share on other sites More sharing options...
Joe X Posted September 4, 2014 Report Share Posted September 4, 2014 Almost same dimensions, power: to sub(s) rated, amp subsonic filter to 28Hz, minimum port clearance 2 1/8", figure is just an assembly guide:NOTE: If building outside you need to build a cardboard dummy box to test fit in it's way inside. Link to comment Share on other sites More sharing options...
LumberZach Posted September 4, 2014 Author Report Share Posted September 4, 2014 Thanks Joe! Link to comment Share on other sites More sharing options...
