DC Sound Lab
DC m3 8" on a 1.2k
Could a run an m3 on a 1.2k? If I wire a dual 2ohm @ 1ohm, it would be seeing 1200w. The m3 has an RMS rating of 600w and a peak of 1200w. Is it bad to run at peak?
If I get a dual 4ohm, I can wire it at 2ohm, which would be about 700w. Is 100w over RMS safe?
On 2/28/2013 at 2:52 PM, Chaise said:
"Now spread your butt cheeks so I can zap your asshole."
2008 Subaru Forester XT
at 1 ohm, you're never going to see full power, after impedance rise.
Hell, you'll probably rarely see 600 watts while wired at 1 ohm on a 1.2k amp.
1996 GMC Sonoma
Four Fi BTL Neo 18's In 2:1 6th Order Bandpass
2 Ampere 5k's @ .5
TEAM FI
TEAM #LITHIUMCANTDEMO
On 10/20/2013 at 0:37 AM, KillaCam said:
Fucking with a Prius driver is like making fun of a disabled kid. Pussies.
Explain why a 1200w amplifier will rarely see 600w, and I'm not being facetious. Maybe I'm missing something about impedance.
Avalanche
Alpine Type S comps
Alpine Type S 10''
Alpine MPR-F300
Alpine MRX-M50
Mechamn 270
XS Power d3400s
I assume he means when playing music, because the power output will vary a lot depending on the sounds you are trying to produce.
When wired to 1 ohm your impedance will most certainly be anywhere between 2-8 ohms. Highly general statement, but it still applies. Different for every application, but bottom line is it is very tough to only rise to 2 ohm while wired at 1 ohm.
1996 GMC Sonoma
2 Ampere 5k's @ .5
TEAM FI
