04 explorer needs some love!
Sup guys wondering if anyone has some more mechanical experience with this vehicle. Mine is the eddie bauer edition with the 4.6 v8
Is ready to roll 101000 miles so I think is time to do a full sweep of maintenance on this thing.
I'm thinking brakes. More than likely green stuff pads. Maybe rotors depending how much meat is left.
I also want to replace all the fluids. Brakes, tranny, radiator, engine, and blinker fluid.
Is there any other thing I should be looking for? Also what brands should I look for when buying the fluids
13 Kia Forte Build!
07 Hyundai Accent Build
***Super Seller***
N8ball2013
And then he gets to say ok all you guys were right. im sorry for being a dummy poo poo head.
Yeah I know there are a few Ford guys on here especially with the explorer.
I gotta see if I have the manual. That would be nice to check lol
13 Kia Forte Build!
***Super Seller***
N8ball2013
Fluid brand shouldn't really matter, but I use all Motorcraft (oem) fluids on mine.
Check the spark plugs!!!
Change the fuel filter!!!
Even if you have no CEL, run a diagnostic. Sometimes codes will pop without triggering the warning light.
Its 10 years old, go through and check all radiator and heater hoses, fuel lines, vacuum lines, and brake lines for any cracks or deterioration.
Fuck Ford LOL.
SMD Super Seller
My Feedback Thread
Be careful when removing the spark plugs. They like to break. It's not as bad on the 2 valve motors like yours, but it's a good idea to start it up and let it get kinda warm first. Can't remember, but I think it only uses 2 coil packs, they need replaced aswell.
Coolant needs to be flushed and replaced. This is REALLY important. Thermostat, waterpump, that simple stuff needs to be done at 100k.
Servicing the trans is kind of a bitch. But it needs to be done, definitely at 100k, fluid drain and a filter replacement.
http://www.explorerforum.com/forums/showthread.php?t=118654
That'll help you out on the tranny service. It's a good idea for the fluid to be warm for that too, just a little light driving, around the block once, back up the driveway once or twice. Ford recommends a full flush, but that's a bad idea in my opinion. You'll drain like 5-6 quarts out when you service it, the rest is all up in the torque converter. 5k miles or so down the road, drain the fluid and put the same amount in. The trans hold like 12.5 quarts or so.
Brakes should definitely be addressed. A full fluid flush, pads, maybe rotors, worst case some new lines if the brakes feel squishy after the rest.
Differential fluid can be replaced now also. Not really neccessary until 150k, but if you have it down for a weekend or so, you might as well do it.
That's all I can think of right now. Some more stuff will come to me later in the day, I'll post up here.
Damn,... That is some good poop.
Now build your system!?
Lol yes
13 Kia Forte Build!
***Super Seller***
N8ball2013
oil: http://www.amazon.com/Genuine-Ford-XO-5W30-5QSP-Premium-Synthetic/dp/B000NU9BNY/ref=sr_1_1?ie=UTF8&qid=1413077394&sr=8-1&keywords=Motorcraft+SAE+5W-30+Synthetic+Blend+Motor+Oil
filter: http://www.amazon.com/Motorcraft-FL820S-Silicone-Valve-Filter/dp/B000AS3D3S/ref=sr_1_1?ie=UTF8&qid=1413077811&sr=8-1&keywords=FL-820S
tranny fluid: http://www.amazon.com/Red-Line-D4-ATF-Bottles/dp/B000VTLJBE/ref=sr_1_4?ie=UTF8&qid=1413078715&sr=8-4&keywords=Red+Line+Synthetic+Oil+-+Automatic+Transmission+Fluid+Part+%23+30504
tranny filter: http://www.amazon.com/Genuine-Ford-Motorcraft-Transmission-Filter/dp/B0042HLTKW/ref=sr_1_1?ie=UTF8&qid=1413079230&sr=8-1&keywords=7A098%28FT-140%29
plugs: http://www.oreillyauto.com/site/c/detail/ACD2/41810/03435.oap?year=2004&make=Ford&model=Explorer&vi=1427802&ck=Search_spark+plugs_03435_1427802_2608&keyword=spark+plugs&pt=03435&ppt=C0334
fuel filter: http://www.oreillyauto.com/site/c/detail/MOT0/FG1083/02515.oap?year=2004&make=Ford&model=Explorer&vi=1427802&ck=Search_fuel+filter_02515_1427802_2608&keyword=fuel+filter&pt=02515&ppt=C0023
thermostat: http://www.oreillyauto.com/site/c/detail/MOT0/RT1196/03442.oap?year=2004&make=Ford&model=Explorer&vi=1427802&ck=Search_coolant_03442_1427802_2608&keyword=coolant&pt=03442&ppt=C0331
water pump: http://www.oreillyauto.com/site/c/detail/MWP0/58584/01398.oap?year=2004&make=Ford&model=Explorer&vi=1427802&ck=Search_coolant_01398_1427802_2608&keyword=coolant&pt=01398&ppt=C0331
coil pack: http://www.oreillyauto.com/site/c/detail/MOT0/DG508/02767.oap?year=2004&make=Ford&model=Explorer&vi=1427802&ck=Search_coil+packs_C2377_1427802_2608&keyword=coil+packs&pt=C2377&ppt=C0334
front pads: http://www.oreillyauto.com/site/c/detail/MOT0/BR114/03351.oap?year=2004&make=Ford&model=Explorer&vi=1427802&ck=Search_brakes_C0068_1427802_2608&keyword=brakes&pt=C0068&ppt=C0009
rear pads: http://www.oreillyauto.com/site/c/detail/MOT0/BR2000/03351.oap?year=2004&make=Ford&model=Explorer&vi=1427802&ck=Search_brake+pads_C0068_1427802_2608&keyword=brake+pads&pt=C0068&ppt=C0009
differential fluid: http://www.oreillyauto.com/site/c/detail/RL00/57104/N2366.oap?ck=Search_differential+fluid_N2366_1427802_2608&keyword=differential+fluid&pt=N2366&ppt=C1985
coolant: http://www.oreillyauto.com/site/c/detail/AFZ2/AF2000/04188.oap?year=2004&make=Ford&model=Explorer&vi=1427802&ck=Search_04188_1427802_2608&pt=04188&ppt=C0059
does any of this look ok and right? also would like recommendations on brands and if you see anything missing please add to the list. i want to get everything done best i can
any help is greatly appreciated.
thank you
13 Kia Forte Build!
***Super Seller***
N8ball2013
PCV valve. takes 5 minutes
edit: double check but I think 100,000 calls for a new belt too. For sure at least inspect it. I had a split in it at 100k
I don't fuck around. I go from zero to I hope you die in less than 2 posts
build log http://www.stevemeadedesigns.com/board/topic/104524-new-subs-coming-sundown-3500d-arc-audio-cable-lacing-crescendo/
