Anand Sayroo Posted October 13, 2014 Report Share Posted October 13, 2014 Hi everyone, I have two american bass hd12d1s . I have a ia 20.1 but I'm thinking to get another 20.1 but I would like to know if i can strap the two amps together with those subs. I'm being told the amps will be stable at 2 ohms but my subs cannot be wired at 2 ohms. Any suggestions? or is there something that I'm missing. I'm looking at the manual and seeing a wattage linked at 1 ohm. Link to comment Share on other sites More sharing options...
SIDE SHOW Posted October 13, 2014 Report Share Posted October 13, 2014 Usually most mono-block amps that are strappable are stable to one ohm by them selves then once strapped they recommend no less than a 2 ohm load.... you may be better just running one amp per sub at 1 ohm Link to comment Share on other sites More sharing options...
RainStryke Posted October 13, 2014 Report Share Posted October 13, 2014 Yeah, the manufacture says it's only 2 OHM stable when they are strapped and they run 4800w RMS @ 2OHM. If 2400w @ 1 OHM isn't enough, then you need to look into a more powerful amplifier... Something like this: http://www.amazon.com/Orion-XTR3700-1D-Monoblock-Series-Amplifier/dp/B00DDZTLZY Link to comment Share on other sites More sharing options...
islandpride684 Posted October 13, 2014 Report Share Posted October 13, 2014 The specs says its stable at 1ohm, strapping two of them will give you a final load at 2ohms at about 4800, not sure if they do rated... Build Log http://www.stevemeadedesigns.com/board/topic/186921-blk9te-07-yukon-slo-mo-build/page-3?hl=%2Bblk9te#entry2881410 Link to comment Share on other sites More sharing options...
RainStryke Posted October 13, 2014 Report Share Posted October 13, 2014 The specs says its stable at 1ohm, strapping two of them will give you a final load at 2ohms at about 4800, not sure if they do rated... From the way I understand it, the final load is 1OHM per sub if he wires them according to the IA20 pdf manual. http://www.incriminatoraudio.com/download/IASeriesManual.pdf Link to comment Share on other sites More sharing options...
islandpride684 Posted October 13, 2014 Report Share Posted October 13, 2014 The specs says its stable at 1ohm, strapping two of them will give you a final load at 2ohms at about 4800, not sure if they do rated...From the way I understand it, the final load is 1OHM per sub if he wires them according to the IA20 pdf manual.http://www.incriminatoraudio.com/download/IASeriesManual.pdf The minimum impedance of two strapped is 2ohms so if he goes below that then he my friend might need a fire extinguisher in his ride...I would just run one amp per sub to keep it simple....he can wire his subs at 2ohms then one sub per amp strapped at 2 ohms... Build Log http://www.stevemeadedesigns.com/board/topic/186921-blk9te-07-yukon-slo-mo-build/page-3?hl=%2Bblk9te#entry2881410 Link to comment Share on other sites More sharing options...
Noel989 Posted October 13, 2014 Report Share Posted October 13, 2014 How can he wire each amp to 1 ohm when he has d1 coils? Build Log - http://www.stevemead...-cruiser-el-pt/ Link to comment Share on other sites More sharing options...
Noel989 Posted October 13, 2014 Report Share Posted October 13, 2014 The specs says its stable at 1ohm, strapping two of them will give you a final load at 2ohms at about 4800, not sure if they do rated...From the way I understand it, the final load is 1OHM per sub if he wires them according to the IA20 pdf manual.http://www.incriminatoraudio.com/download/IASeriesManual.pdf The minimum impedance of two strapped is 2ohms so if he goes below that then he my friend might need a fire extinguisher in his ride...I would just run one amp per sub to keep it simple....he can wire his subs at 2ohms then one sub per amp strapped at 2 ohms... The amps are strapped it makes one big amp out of the 2 how can he wire Each sub to each amp??? Build Log - http://www.stevemead...-cruiser-el-pt/ Link to comment Share on other sites More sharing options...
islandpride684 Posted October 13, 2014 Report Share Posted October 13, 2014 The specs says its stable at 1ohm, strapping two of them will give you a final load at 2ohms at about 4800, not sure if they do rated...From the way I understand it, the final load is 1OHM per sub if he wires them according to the IA20 pdf manual.http://www.incriminatoraudio.com/download/IASeriesManual.pdf The minimum impedance of two strapped is 2ohms so if he goes below that then he my friend might need a fire extinguisher in his ride...I would just run one amp per sub to keep it simple....he can wire his subs at 2ohms then one sub per amp strapped at 2 ohms...The amps are strapped it makes one big amp out of the 2 how can he wire Each sub to each amp??? Using the master mirror option..my bad it was late my thought process was off, if you want to run it at 1ohm per amp using the mirror option, you need D2 subs, but since he has D1s he needs to wire them at 2ohms per sub to each amp, but using the master/slave option he can do it but it'll have to be at 4ohms...so both subs with a final of 4 ohms then the to the amps Build Log http://www.stevemeadedesigns.com/board/topic/186921-blk9te-07-yukon-slo-mo-build/page-3?hl=%2Bblk9te#entry2881410 Link to comment Share on other sites More sharing options...
SIDE SHOW Posted October 14, 2014 Report Share Posted October 14, 2014 Yeah i'd prob suggest you sell that amp and get something you can use with your duel 1 ohm subs Link to comment Share on other sites More sharing options...
