Patrick Saxon Posted October 24, 2014 Report Share Posted October 24, 2014 I got a sundown saz1500d gonna be powering 2 lvl 4 15s dual 2 ohms. i have the big 3 going in tomarow .145amp alt and a shurkin bt 45 extra battery all 0 gauge everything Link to comment Share on other sites More sharing options...
Smoove Posted October 24, 2014 Report Share Posted October 24, 2014 no 2 Team Fi 15's v1 2 DD M5's 970amps of Alt 6th order blowthroughThe truck Blowthrough build : http://www.stevemeadedesigns.com/board/topic/155555-smooves-1996-chevy-ext-cab-c1500-slow-build/The 350z build : http://www.stevemeadedesigns.com/board/topic/170694-smooves-2003-nissan-350z/ My FB page https://www.facebook.com/pages/Smooves-Car-Audio-and-performance/719746144805343 Team Fi Audio http://www.ficaraudio.com/ Link to comment Share on other sites More sharing options...
Patrick Saxon Posted October 24, 2014 Author Report Share Posted October 24, 2014 no cause the amp or my electrical Link to comment Share on other sites More sharing options...
alaskanzx5 Posted October 24, 2014 Report Share Posted October 24, 2014 Because you had to ask. t1500bdcp 2 t2d4 15" 1 t600.4 1 t400.2 1 set p1 tweets singer alt, tons of wiring, smd vm-1, 80prs, back seat delete, still in the works, aiming for a 145-147 with the ability to play 25hz up to 50hz. Link to comment Share on other sites More sharing options...
Patrick Saxon Posted October 24, 2014 Author Report Share Posted October 24, 2014 whatever bump Link to comment Share on other sites More sharing options...
Cardboardcat15 Posted October 24, 2014 Report Share Posted October 24, 2014 Never run below manufacturer's ratings, that's always my advice. General consensus about .5 is "if you have to ask, don't do it." My Channel on YouTube. Check it out for cinematic-style Car Audio videos. https://www.youtube.com/channel/UCcSMhtT-rpopJbdybubDgnQ New 2014 Scion TC 4th Wall Build https://www.stevemeadedesigns.com/board/topic/217173-2014-tc-4th-order-build-3-fi-sp4-15s/ Link to comment Share on other sites More sharing options...
Nightshade Posted October 24, 2014 Report Share Posted October 24, 2014 No for several reasons. First your electrical is not stout enough. That amp alone can pull more current than your alternator can put out. Also the battery that you are running is too small. On top of that you aren't going to see that much of a difference dropping down to .5 ohms for daily. If you were a competitor and just wanted to burp at .5 ohms then I'd say that you'd be fine for that but not music. A couple hundred extra watts isn't going to be worth frying your amp over. You should get the correct ohm subs and then try again. I would suggest dual 1's so you can run the amp at 1 ohm where it is meant to be operated at. 2013 VW Jetta GLI 2.0 Turbo 1 Sundown Audio SCV2000 1 Sundown Audio X15 V2 1 XS Power D3100 Audio Control LC6i Stock Deck 146.4 sealed on the dash at 37hz 2001 Focus ZX3: RETIRED Team Sundown Audio, Team XS Power, 2 time NSPL Car 3601-Up Champion, 2 time NSPL Car Hardcore ChampionHighest NSPL Scores to date:154.3db on the dash sealed at 46hz, 156.2db in the kick at 46hz155.2db unofficial on dash at 43hz Link to comment Share on other sites More sharing options...
Kyblack76 Posted October 24, 2014 Report Share Posted October 24, 2014 Go ahead and do it...... You know your going to anyway..... SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold Link to comment Share on other sites More sharing options...
Tarball Posted October 24, 2014 Report Share Posted October 24, 2014 Post a video and pics after your fry stuff. Always good for a laugh Experience is the best teacher sometimes, that and having to empty your wallet for new stuff. CURRENT SYSTEM: Alternator: Stock alt on mids/highs Isolated DC Power 270 SP - Charging @ 16.8v Batteries: (2) XS D1400s Power Cable: Double Runs of 1/0 KNU Kolossus Fleks Headunit: 80-PRS Sub Amp: DC 5.0k Subwoofers: 2 RE MT 15s /PSI dual .7ohm recones Subwoofer Enclosure: 9.1cubes @ 32hz - brutal. Mids & Highs Amp: CT125.4 Active Components: Mids RE XXX 6.5c Highs - 3 RE XXX tweeters per side(A pillar) Noise Control: Damplifier Pro all over the cab. Build Log If you do business with me please leave feedback here: FEEDBACK THREAD Highest Legal Score: 151.0 db Highest Musical 30 Second Average: 151.6 db Link to comment Share on other sites More sharing options...
Phaeton Posted October 24, 2014 Report Share Posted October 24, 2014 Can you? hell yeah. Should you? Nope. 1997 subaru legacy outback Four 15's in a almost wall Rockford Fosgate t2500-1bdcp Rockford Fosgate T400-4 on tweets Rockford Fosgate T400-4 on highs Rockford Fosgate T400-2 on midrange Rockford Fosgate T400-2 on midbass Optima Yellow top batteries 270A Singer alt (working on a bracket for a second) Lots of Second Skin Link to comment Share on other sites More sharing options...
