Syphlyn Posted October 24, 2014 Report Share Posted October 24, 2014 (edited) Finally got this all sorted out. Josh from mechman is a great guy! Edited October 24, 2014 by Syphlyn Quote Syphlyns 2000 F150 4.6L V8 H/U: Kendwood KDC-X898 Speakers: 4 x Alpine SPR-68 Speakers 4 Channel Amp: Alpine PDX-F4 Sub: Sundown Zv4 12 Sub Amp: Sundown SAZ-2000D Box: 2.75 Cu Ft @ 31Hz Alternator: Mechman 250A elite series Wiring: All KnuKoncepz 0 gauge OFC + KnuKonceptz Krystal RCAs Link to comment Share on other sites More sharing options...
Kyblack76 Posted October 24, 2014 Report Share Posted October 24, 2014 6phase/hair pin for lower turn on speed. What does that say it does? Like 120 at idle? so maybe around 80-90 real world? Quote SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold Link to comment Share on other sites More sharing options...
ChevyBoy95 Posted October 24, 2014 Report Share Posted October 24, 2014 6phase/hair pin for lower turn on speed. What does that say it does? Like 120 at idle? so maybe around 80-90 real world? Older mechman's that I have used that were 125a at idle did like 100+ hot at idle, OP, does your alt have a small pulley on it? b/c you might need a smaller pulley to get the RPM on the alt up to put something out at idle. Quote Best Score to Date : 160.5 dB Outlaw (47Hz)[4 XM 15's & 2 Taramps Bass 12k's] BL : http://www.stevemeadedesigns.com/board/topic/147800-chevyboy95s-4-15s-7krms-wall-1533-db-on-half-power/YouTube: http://www.youtube.com/hitemwiththeflex/ Link to comment Share on other sites More sharing options...
Syphlyn Posted October 24, 2014 Author Report Share Posted October 24, 2014 (edited) 6phase/hair pin for lower turn on speed. What does that say it does? Like 120 at idle? so maybe around 80-90 real world? Older mechman's that I have used that were 125a at idle did like 100+ hot at idle, OP, does your alt have a small pulley on it? b/c you might need a smaller pulley to get the RPM on the alt up to put something out at idle. Yeah it came with a small pulley on it, but it's not even putting out enough at idle to maintain a charging voltage it just drops right to 12.6-13.0. I was told prior to purchasing I should be 135-140 amps @ 6-700 rpm...lol my stock alt is 130a (probably does that around 2000-2500 rpm) and it put out way more at idle. Edited October 24, 2014 by Syphlyn Quote Syphlyns 2000 F150 4.6L V8 H/U: Kendwood KDC-X898 Speakers: 4 x Alpine SPR-68 Speakers 4 Channel Amp: Alpine PDX-F4 Sub: Sundown Zv4 12 Sub Amp: Sundown SAZ-2000D Box: 2.75 Cu Ft @ 31Hz Alternator: Mechman 250A elite series Wiring: All KnuKoncepz 0 gauge OFC + KnuKonceptz Krystal RCAs Link to comment Share on other sites More sharing options...
