Bmw 740 SQ/SPL Kicker WarHorse, GZ, Focal Utopia By NautiluzCreation
Started building in a friends car, he has for several years brought a nice mix of the best equipment I have tested in my cars.
So this will be a SQ/SPL build. What we are using are:
Pioneer DEH-P80RS
Helix DSP
Alpine F1 Status MRV-F900
Kicker WarHorse 10000.1
Ground Zero Plutonium 15QX
4pcs Optima 75amp
50amp Powermaster charger.
Started with welding a steel frame 20x50mm into the cars chassi.
Steel frame welded.
Upper part must be detachable, so I weld 4 nut in the lower part.
Frame for the upper part.
Upper part is angle 15 degrees before welded.
3rd part and top part of the frame :)
Charger mounted and all parts are painted black.
Enclosure is made by CNC router..
Front baffle is made by 2pcs of 19mm MDF
CNC routed rings for 2pcs of 6" aeroports.
Enclosure is reinforced in the top an bottom with a 6mm steel plate..
My car audio build page on facebook: www.facebook.com/nautiluzcreation Store: www.nzc.no
Skjermbilde%202015-11-23%20kl.%2022.39.3
good stuff!
1997 subaru legacy outback
Four 15's in a almost wall
Rockford Fosgate t2500-1bdcp
Rockford Fosgate T400-4 on tweets
Rockford Fosgate T400-4 on highs
Rockford Fosgate T400-2 on midrange
Rockford Fosgate T400-2 on midbass
Optima Yellow top batteries
270A Singer alt (working on a bracket for a second)
Lots of Second Skin
Front baffle that is seen from inside of the car.
Finally the subwoofer box is inn for testing.
And so is the WarHorse :D
And the Alpine F1 status
Inside of the subwoofer box I will be using av type for white alcantara that contains a lot of silver..
Inside wrapped
Speaker cables 8mm2 and Speakon connectors.
Finally it is in and out of the car for the last time..
Yes.. I really meant for the last time! :D
Fuses for WarHorse 3x300amp
10mm MDF plate wrapped with vinyl. To place fuse holders on.
Batteries mounted and fuses on top. :)
Dynamat on both sides of the rear seat wall.
Last wall in the subwoofer box. For mounting of plexiglass
Wrapped with alcantara, didn't use so much time on this one since it isn't actually visible. Unless through reflections from magnets or so.
Bottom plate, with my logo
Tec7 on the bottom to secure the white plexiglass
Lexan :yahoo: 6mm tinted
Making rest of the holes in the new warhorse cover.
Moving the logo 2" to the left...
Final touch..
Testing some light setting..
More to come!
In the words of Joe Dirt....DAAAAAAAAAAANG!!!! Very nice work.
01 Suburban Z71 - 5.3L - Black - 6" Lift on 35's - Pioneer H/U - Kicker Mids, 8" Polk sub.
Past rides-
07 Avalanche - Sunburst Orange - 4/6 Drop - Pioneer AVH-X5600 - 2/0 Royal Excelene - T/M fuse blocks - Stock and Singer 350 Alts - 4 Kinetik 1800 - Crecsendo BC5500 & S800.4 amps - 2 Tantric HDD 18's.- RE XXX 6.5 comps
01 Grand Vitara - V6 - 4x4 - Pioneer H/U - Incriminator 6.5 Comps - SSA XCON 18 - Skar 1500.1 & 84.4 amps - Singer 160 Alternator - Optima Yellow top..
HOLLY BALLS BATMAN!
what adhesive u used for the metal sheet to bod on the mdf?
REFF'S
My link
EBAY
http://feedback.ebay...ck&myworld=true
I love car audio so much because I will never be done. I can never win, and I will never get it finished or perfect. It always has me coming back for more, I can never get my fill of it, but I get what I need.
Wrapped 6" aero ports with carbon vinyl.
Going to bend plexiglass 90 degrees.
Using it as a cover for the positive
All of the cables with sleeves.
Will try to get the look as original as possible..
Sanding...
  • Who's Online   0 Members, 0 Anonymous, 384 Guests (See full list)
