DD 715 Box Design.help to review and improve my design
Hansom Sarwan
Ok so im looking for a change from my current 2 12" sundown SA
im looking at getting a single 15 DD 715 since the Sundown require alot more power
The amp i have is a orion 1200D mono rated 1200rms @ 12.8V
The 715 DD is rated 1200rms/3600watts
MY BOX DESIGN
5cuft after port and subwoofer displacement
80sq inch of port area
port length 18"
i could have done a single 5" slot port however i did 2 2.5" ports on eitther side with the length of the port 18" on both sides
How can i improve this design for better output
i would like to obtain frequency response from 32-55hz so that it can play low tones but yet higher tones in upper 40-50 region
Picture of box design below in link
http://s375.photobucket.com/user/Hansom_Sarwan/media/5cuftddbox15_zps79a8a4c3.png.html?filters[user]=142168107&filters[recent]=1&sort=1&o=0
In your design that you made, what did you tune the ports to? 18" with that much port area seems pretty short.
Builds:
Yeah, I wasn't thinking straight or something. 18" long port will tune a single 80 sq in port to about 34 Hz, which is very reasonable considering what you want to do. If you go with two ports they will need to be a little longer, about 26" to get the same tune.
Typically one large port is most efficient, however you have a pretty healthy amount of port area, so if you want to do two 40 sq in ports you should be fine.
Builds:
Maybe im missing something, but if your sas witch are more cone area than a single 15, can take more power than than the 1.2k amp you have...
You simply get a bigger amp. You wouldnt imo downgrade on subs. Which requires a new box as well.
Youre spending money on new sub and new box, when ur money is better served getting a 2k amp..
Setup:
2010 Hyundai Elantra
Factory Unit via 4 chan NVX LOC
Excessive Amperage "H/O" Alt
Xs D3400/ Xs XP3000
Big 3. 2 Runs of +, 2 Runs of -
DD M3b and 2 12" AQ HDC4s
  • Who's Online   0 Members, 0 Anonymous, 233 Guests (See full list)
