This isn't my first build, but it is the first that i am documenting. I am not an expert, but I do think i know as much or more than anyone working at my local shops. That being said I have a lot to learn. The build is nothing too special, I am happy with it and open to suggestions/ constructive criticism and questions.
The Car Details:
2005 MINI Cooper S (R53), 65K miles, chrono package, NON-JCW.
So far:
Performance/Appearance
-Strut Tower Reinforcement Plates
-LED Fogs and Running lights
-Conti Extreme Contact DWS's
-10% Tint all around.
-Cravenspeed Stubby Antenna
-Cravenspeed Dipstick
-17% Cravenspeed Pulley (w/ 532 belt)
-NGK 7 Colder Spark Plugs
-ATI Racing Crank Pulley
-ScanGauge 2 (boost, AIT, voltage, ect)
-5Zero4 R53 Door and and scoop graphics (not yet installed)
-DDM powdercoated intake with Dry paper Filter
-Upper Motor Mount From Greene Performance
Audio
-Pioneer DEH-80PRS
-Stock component tweeter and 5.25" frontstage (alpine or Harmon Kardon made them) and stock 6x9 rears
-XS Power D4700 battery (in stock location in the rear floor)
-SHCA OFC 1/0 run front to back and for grounds for Big 3, also used for amp +/- all fused with SHCA fuses
-SHCA RCAs
-LC-1
-SHCA 8 gauge OFC wire for speaker wire
-Sundown ZV.4 10"
-Sundown SAZ-2500D v.2
-Custom Box 1.5 cuft net, tuned at 32 Hz wrapped in red (Thanks to JoeX for the design help)
Coming Soon Eventually (In no particular order)
-Chrome delete/blackout
-Rear seat delete
-Custom Exhaust (header back, prob catless)
-RMW fully built 1.8 or 2.0 Liter Stroker Engine
-RMW "Jesus" Head
-RMW Custom Race Header
-RMW Grand Am Cam
-RMW Tune
-Borg Warner Turbo, TVS, or Rotrex Supercharger Upgrade (I'll decide when i cross that bridge)
-Meth injection Kit
-Vipec ECU
-Suspension Upgrades
-Enkei Racing PF01 17" wheels
-R56 big brake swap
-Roll cage/6point harnesses.
-Front stage and rear fill upgrades and amp
-Switching the Zv4 10" for an 8" or 2 for weight/charging
-Singer Alt (still discussing practicality due to stability issues at High RPM, NOT MIKE'S FAULT)
-Sound deadening (If I track the car i will not be worrying about this but if it remains a DD then I will)
Notes
I recently graduated with a biology degree and am headed soon to complete a masters of medical sciences. From there it will be off to Med school, so this will be a slow build. The second issue is that this is my daily so, I cant do anything that will put it out of commission for more than a weekend. Some of the stuff I listed is wishful, but I do plan on getting everything listed eventually if i can keep this car and get a different daily (possibly post grad or medschool). I have and probably will continue to do all the work myself. Im learning as I go.
PICS COMING SOON! :peepwall:
Life's a trip. . . Don't fall.
The Xenon Pic is older that's why it has a license plate holder on it still. Finally the Big three and box install. (no judging on my wire color and heat shrink. Im broke and used what i had. Haha). The amp setup is temporary, though the box came out really solid so mounting there wouldn't be that bad. I just don't want to chance it. I'm trying to figure out something more permanent. Well Let me know what yall think. Im considering getting a single bank of the 3000farad Maxwell caps as I need to save on weight and my voltage is pretty stable for about 30 seconds at full tilt and i usually listen to it way below that.
Additional Notes.The Alt to batt wire was run underneath the vehicle along side the factory run. It is fused. then the run from the battery to the amp is fuse in the middle at the only place possible but the fuse is less than 18" from the batt. On the grounds that you see, I attempted to ground to the alt case, but it was impossible to safely run the wire due to the belt. The location I chose is only a few inches from the alt and unlike the factory ground which is to the engine mount mine is actually to the block. There is a raised bare area that is pretty much the exact size of the SHCA copper lugs. That's why it looks like there is paint under the ground. Only the tip of the bolts are painted, the threads are clean. I have since added additional washers to the battery terminals for a more secure connection.
Building a box on carpet in bedroom, Basslife.
Speakers mounted to cooler, basslife.
Love it, tuned in
2007 Chevy Tahoe (SOLD)
2 ~ DC Audio 5.0K @0.67
3 ~ DC Audio 5.0K @1.0
1 ~ XS Power D4800
1 ~ XS Power D3400
8 ~ XS Power XP3000
320+ Sq. Ft. Sound Deadener
Pioneer AVH-X5500BHS
  • Who's Online   1 Member, 0 Anonymous, 1715 Guests (See full list)
