XS Power
is this bad for my d3100?
I just stuck one of my (2) d3100 in yesterday. On the floor of my trunk. Until I take my hc2400 out and put both d3100 on top of the box. Well its only been 4 degrees out side over night and all day today. Took alook in the trunk when I got home and the d3100 is frosted over. Is this bad for the batt? The hc2400 is dry that is on top of the box.IMG_20141226_144906_606_zpskhzihn91.jpg
01 focus se
110 amp alt
Big 3 sky high and stinger hpm ofc 1/0
Super start platinum AGM (starting)
2 runs of 1/0 Execution audio front to back
Kenwood double DIN DDx271
A pillars- orion 4" super tweeter and 2-1" alpines.
Orion xtx 64 in the front doors
2:1 4th order bandpass
Sealed off trunk
Digital designs deadener on roof/ rear deck
Orion hcca 12s (black coils)
Orion xtr3700.1
Orion xtr250.2 mid/highs
All sky high 1/0 in trunk dual runs(power/ground)
Sky high dual 1/0 inputs
2 xs power D3100 in back
Sky high batt blocks
Rose audio batt blocks
Stinger volt meter
All sky high 1\0 fuse and holders
Db link remote/ rca
Nope not bad. Doesn't make a bit of difference to the battery. The amp on the other hand... If it's frosting/condensing on the battery I'd think it should be happening on everything in the trunk. Do you have any leaks anywhere?
Not good inside your trunk. You need to put in garage and dry the trunk up something causing moisture in there. Water under sub box in wheel well? check your wheel wells also for leaks. Poor amp! Voice coils!
Pioneer P99RS
Ampere 3800
2-Ampere 125/4
4-6.5 inch Hertz HSK XL Mids
2-5.25 Satori Mids
2-Hertz Silk tweeters
DC Audio Level 5/12
Skyhigh Wire
Mechman 320
XS Power D3100
Only thing in the trunk that has frosted was that batt. All the rest of it is dry. I don't even think the floor is wet. But I got to go back out and take a look.
01 focus se
110 amp alt
Sealed off trunk
Orion xtr3700.1
Stinger volt meter
Db link remote/ rca
None of the carpet is wet at all in the trunk. Its just that d3100. My wife just told me she took that car to the gas station, that's down the interstate about 5 miles one way. I went and took a look and the only thing I can think of is. The weather stripping is kinda jacked up at the latch. And could have let air in. onto that batt going down the road. But if I don't have problems with the batt getting that cold then I'm OK for now.
01 focus se
110 amp alt
Sealed off trunk
Orion xtr3700.1
Stinger volt meter
Db link remote/ rca
Is it dry when you first open the trunk? Or after driving?
Probably from sitting on the floor metal gets cold and then the battery case gets cold
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
Idk lol. Its only been in for a day. And I didn't drive it today. As its not my daily. I put it in, it sat over night and my wife took it to the store quick. Checked it out when I got home and it was like that. I bet n8 is on to it.
01 focus se
110 amp alt
Sealed off trunk
Orion xtr3700.1
Stinger volt meter
Db link remote/ rca
This.
There's almost always moisture in trunks. There's vents back there ;)
  • Who's Online   0 Members, 0 Anonymous, 1608 Guests (See full list)
