Jhunt94 Posted May 1, 2015 Report Share Posted May 1, 2015 From looking at both of your builds, I can tell you're definitely not afraid to pull motor apart lol 2007 Ford F-150 Reg. Cab. Flareside250 Mechman AlternatorSky High Car Audio Big 3 XS Power D3400Rockford Fosgate 1/0 amp kitRockford Fosgate T1500-1bdcpRockford Fosgate T400-4DC Audio Lvl 4 12"Rockford Fosgate Punch 6.5" componentRockford Fosgate Punch 6x8Pioneer AVH-P2300DVDSMD Volt Meter Link to comment Share on other sites More sharing options...
Deeznutz Posted May 1, 2015 Author Report Share Posted May 1, 2015 Yeah, but only way to make it roll is to fix it! I have to say one thing though, my old man was right, automotive repair CAN BE BIG MONEY. I see now why he wanted me to do it. Plus, Lisa gets turns on in some weird way when she sees me all dirty and greasy. Don't get it? lol. -Frank Link to comment Share on other sites More sharing options...
Jhunt94 Posted May 1, 2015 Report Share Posted May 1, 2015 If only more women appreciated the look of a working man, that isn't afraid to get dirty lol 2007 Ford F-150 Reg. Cab. Flareside250 Mechman AlternatorSky High Car Audio Big 3 XS Power D3400Rockford Fosgate 1/0 amp kitRockford Fosgate T1500-1bdcpRockford Fosgate T400-4DC Audio Lvl 4 12"Rockford Fosgate Punch 6.5" componentRockford Fosgate Punch 6x8Pioneer AVH-P2300DVDSMD Volt Meter Link to comment Share on other sites More sharing options...
Deeznutz Posted May 6, 2015 Author Report Share Posted May 6, 2015 With the cover removed you could see antifreeze and oil mixture. (Cash register sound clicking in my ear) Keeping things organized. Cleaned all the sludge off the rods. The cylinder heads are off. This is passenger side. The middle cylinder is #4. The intake port is tan when it should be black. I was getting a code for "Misfire Cyl. 4". The computer was right. The spark plug is still white in comparison. This place comes recommended by my automotive friend of mine. Even if I rebuild the heads, I have no way to pressure test or check for breaks without special equipment. They called and said the cylinder(s) have cracks present. I gave the OK to repair my cylinders. I resurfaced the intake the old fashioned way. 180 grit, spray glue, perfectly flat wooden board. Passed the light test when completed. Simple Green Degreaser, pressure washer, scrub brush and elbow grease! -Frank Link to comment Share on other sites More sharing options...
Bump4life Posted May 6, 2015 Report Share Posted May 6, 2015 good work man!!! i have a love/ hate relationship with engine work. Buyer/Seller Feedback Thread: http://www.stevemead...5015-bump4life/ MB C220 153 Trunk Car Build Log: http://www.stevemead...d/#entry1840136 MB C280 Ipad Dash SQ Build Log: http://www.stevemeadedesigns.com/board/topic/194484-bump4lifes-new-benz-tony-c-relay-kit-pictures-ce-electric-audison-front-stage-installed/ My SPL Log: http://www.stevemead...__fromsearch__1 BMW M340 xDrive Stock, for now. Corner Load 10" maybe soon. But does 10s in the 1/4... Best Scores out of a trunk 153.0 sealed legal full tilt clamped 5524 @ 42 hz 154+ windows down, 155+ kick Link to comment Share on other sites More sharing options...
ROLEXrifleman Posted May 6, 2015 Report Share Posted May 6, 2015 How long would you say the ordeal is? I have a feeling I will have to do this as well, at minimum the intake leaks. Rolex you sicken me. Just let me finish my pie ~ Juice Link to comment Share on other sites More sharing options...
Deeznutz Posted May 7, 2015 Author Report Share Posted May 7, 2015 How long would you say the ordeal is? I have a feeling I will have to do this as well, at minimum the intake leaks. So far I spent about 730-1500 removing all the bolts and wires/plugs just so I could remove the top plenum piece. I took a pic of EVERY bolt and nut with it's respective socket size so I can refer back to the pics and work my way backwards. Then I spent the next day 0900-1500 removing both cylinder heads which was a complete bitch because you could not remove the last valve cover bolt without removing the engine hoist harness/handle. After that, you had to fight the header bolts. Get up under the car for the back 3, than up top for the last 2 screws. The entire assembly nut and thread came out as one!!! The passenger side engine handle was held inplace by 2 13mm bolts, which could only be accessed with the right size 13mm socket. Took me about 45 min to remove that handle thing. This thing sits behind the valve cover end. You only have about 2 inches clearance before you hit the firewall! I could only pull the ratchet with my hand open-with my fingers- since the oil drip stick was in the way! I suggest you only do this if you have another car you can drive around til it's rebuilt. Today I picked up the Fel-Pro gasket kit. Advance Auto Coupon Code WD518 saved me $50.00 so $159 OTD, instead of $175+tax at National Cylinder! Tomorrow I pick up the cylinders. -Frank Link to comment Share on other sites More sharing options...
Broke_Audio_Addict Posted May 8, 2015 Report Share Posted May 8, 2015 I'm sure you know but just incase you dont absolutely do not reuse the intake or cylinder head bolts. That being said a lot of people's definition of "music" is a clipped 30 hz sine wave with some 80 IQ knuckle head grunting about committing crimes and his genitals. Link to comment Share on other sites More sharing options...
Bump4life Posted May 8, 2015 Report Share Posted May 8, 2015 I'm sure you know but just incase you dont absolutely do not reuse the intake or cylinder head bolts. depends on the car. most are one and done though. for peace of mind i always would get new bolts. they can be expensive though! Buyer/Seller Feedback Thread: http://www.stevemead...5015-bump4life/ MB C220 153 Trunk Car Build Log: http://www.stevemead...d/#entry1840136 MB C280 Ipad Dash SQ Build Log: http://www.stevemeadedesigns.com/board/topic/194484-bump4lifes-new-benz-tony-c-relay-kit-pictures-ce-electric-audison-front-stage-installed/ My SPL Log: http://www.stevemead...__fromsearch__1 BMW M340 xDrive Stock, for now. Corner Load 10" maybe soon. But does 10s in the 1/4... Best Scores out of a trunk 153.0 sealed legal full tilt clamped 5524 @ 42 hz 154+ windows down, 155+ kick Link to comment Share on other sites More sharing options...
Deeznutz Posted May 8, 2015 Author Report Share Posted May 8, 2015 Heads are back, nice and squeaky clean. Yes I have new head bolts. I have to clean off the thin paint from the mating surfaces (right cylinders already done). The guy said I could install it as is or wipe them off. I'm debating whether or not to rid the cylinders of this thin paint coating and spraying it aluminum gray, then hitting the valve covers and plenum with red and black paint as a contrast. Black plenum, red covers, or vise versa. -Frank Link to comment Share on other sites More sharing options...
