box for HCCA 15 D4
dsw422
hey everyone.. need help with designing a box for a buddy.. he going to run an hcca 15 d4. Max box size is 40"w 17"t 29"bottome depth and 22" top depth.. He wants the sub to be facing up and 2 ports facing up as well.. enclosure recemendation is only 3.5 cubic feet which i think is odd.. any way.. help is much appreciated.. oh and hes going to b running a RF 1500.1
2014 Ford Focus SE Sedan
Factory Sony 10 Speaker Sound System
1994 Ford Bronco
Dual head unit (i kno)
Sony door speakers
Kenwood Rear Speakers
Custom Center console in the works. will house an NVX NSW10"
https://m.facebook.com/WinnsCustomCarAudio/
HCCA like a smaller box. Had a HCCA 10 that jammed very hard. 1 big port instead of 2. 1500 weak for that sub. Give it 2500.
Pioneer P99RS
Ampere 3800
2-Ampere 125/4
4-6.5 inch Hertz HSK XL Mids
2-5.25 Satori Mids
2-Hertz Silk tweeters
DC Audio Level 5/12
Skyhigh Wire
Mechman 320
XS Power D3100
oh ok.. my buddy really wants 2 but ill see what he says.. if i could get desings for either would be great.. the dimensions i sed can me modified as needed..its just the max.. if a regular shape box is better, then let me kno.. and ill let him kno to try and get the larger amp.. thanks
1994 Ford Bronco
Sony door speakers
Here is a suggestion, power: to sub rated, amp subsonic filter to 28Hz, minimum port clearance 3 1/2", figure is just an assembly guide, bracing is 1 1/4" wooden dowel rods:
NOTE: If building outside you need to build a cardboard dummy box to test fit in it's way inside.
  • 1 month later...
so i made the box for my buddy, and turns out i was off by just a little on my measurements.. i should have made the box 1.5 inches narrower.. the rear corners are hitting on the back side trim.. since the body comes down at an angle, instead of straight down, it hits right there.. it didnt allow the back seats to lock in place..
soo, to fix my mistake, i cut just the material away that was hitting.. still gotta sand and repaint, but looks good i think..
only question i have is, would the tuning frequency be affected by this?? on the port side, i just cut away the material hitting and assumed since it'll be a tight fit to the interior, the interior will act like the rest of the port...
here are some pics of what he is putting in it and my fix.. oh and in the pics the box is on its side.. just want to make it clear it is a top mount box!! its on the side to work on it.. lol
dont mind all the wood filler.. lol..
1994 Ford Bronco
Sony door speakers
  • Who's Online   0 Members, 0 Anonymous, 1058 Guests (See full list)
