Oscope and Test Tones
damato300x7
So I got a DSO 201 Nano. I have a question about what test tones to use to set gain. I am running a 3 way active front stage. Here are my crossover points.
Sub - 80hz and under
Mid bass - 80hz - 500hz
Mid range - 500hz - 5000hz
Tweets - 5000hz and up
I was going to use the following
40hz for sub
300hz for Mid bass
3000hz for Mid range
7000hz for Tweets
This sound correct?
Thanks for the help
  • 2013 Dodge Dart
  • Factory HU
  • Rockford Fosgate 3sixty.3
  • Alpine V9
  • Alpine F4
  • Hertz HT-25 Tweeter
  • Hertz HL-70 Mid-Range
  • Hertz HV-165L Woofer
  • Raspberry Pi - Running OSMC using optical out to 3Sixty.3
  • Wiring - Sky High Car Audio
Build Log - http://www.stevemeadedesigns.com/board/topic/190450-2013-dodge-dart-american-bass-install/
Sub - 40
Mid bass - 250
Mid range - 1000
Tweets - 5000
that is where i would set the gain at.
At the same headunit volume, the lower the frequency the higher the ACV on the output (RCA's), so set it towards the bottom of the range of frequencies.
If you set your bass amp with say 50hz @ 0dB and then play a 30hz @ 0dB tone, you will be clipping heavily.
40hz on the lows amps.
1000hz on the high amps.
your gain overlaps are up to you but for me -10db on bass, -5db on mids/highs (give or take a db). Use a 0db track on all incoming signals (deck/eq/x-over/linedriver)
done.
Follow my Tweet (Twitter)
Thanks guys for the responses. One more question. I am using factory HU going into a 3Sixty.3 should I check the RCA out of the 3Sixty first then go to speaker terminals out of amp?
Steve, would 1000hz tone work on the tweet amp being that is playing 5000 and up or adjust the crossover to somewhere under 1000 then set the gain then re-adjust my crossover points?
Thanks
  • 2013 Dodge Dart
  • Factory HU
  • Alpine V9
  • Alpine F4
Ahhhh gotcha!
Thank you very much!
  • 2013 Dodge Dart
  • Factory HU
  • Alpine V9
  • Alpine F4
  • Who's Online   0 Members, 0 Anonymous, 1053 Guests (See full list)
