bigsausagepizza Posted February 12, 2015 Report Share Posted February 12, 2015 I'm planning my build for this year, my current setup only plays well down to ~35hz, and I'm hungry for the low-lows. I listen to a lot of decaf and also metal with extremely low tuned guitars/basses and I'm missing those earth shaking low notes. I'm looking for a 10 or 12 that can get down in the 20-25hz range, with a maximum box size around 2 cu ft. I know Hoffman's iron law, so I know this won't be the most efficient, but I'm shooting for deep extension and small enclosure. I plan on powering this with a Crescendo S1500.1 running at either 1500+ at 1 ohm or 1000 at 2 ohms (for electrical efficiency). Not looking for a VS thread, just suggestions that fit my criteria -Play down to 20-25hz -Maximum box size 2.5 cu ft (external) - RMS ~1000-1500 As a side note, how do you hatchback and SUV guys secure your boxes? My spare tire and tools are under the rear floor and I still need access to them. 2008 Subaru WRX STI K&N Typhoon Intake Invidia Polished Stainless 3" turbo back with cat Cobb Accessport Dyno tune from Kaizen Tuning 320awhp 330ft-lb awtq MTX 421D Sub amp American Bass SQ900 Highs/Mids amp Sundown Audio SD-2 10 D4 JL Audio XR653-CS 3-way Components 3sixty.2 Second Skin Damplifier Pro Custom fiberglass wheel well enclosure Transmission Line quasi-floor enclosure http://www.stevemeadedesigns.com/board/forum/13-member-rides-builds-show-off-your-whip-show-off-your-system/ Bill Fitzmaurice TLAH line-array hifi towers 9 Goldwood 4" mids (each) 12 Goldwood 1/2" tweeters (each) NAD 1020 Preamp MiniDSP 2x4 Balanced processor Thorens TD166mkII Turntable Hafler DH-200 Amplifier http://www.stevemeadedesigns.com/board/topic/192638-line-array-hifi-tower-build/ https://www.facebook.com/HolyMountainGlass Link to comment Share on other sites More sharing options...
philrab Posted February 12, 2015 Report Share Posted February 12, 2015 Most subs will dig fairly low if the port is appropriately tuned. 2.5 cubes outside the box, I'd be looking at a 10 personally, my SA12 is tuned to 33 hz but the box is like 3 cubes before port and sub displacement.I was fortunate to have tie down hooks in the hatch of my Mazda 3, so I have a steel chain lanyard firmly attached to the box with lots of screws and body washers (could also make a steel backing plate and run bolts through with a dab of silicone in each bolt hole) and a D ring caribiner on the end to attach to I can quickly remove it if need be. 2015 Toyota Tacoma Build Thread 2007 Mazda 3; 5000K HID's, Kenwood Excelon KDC-X997, Infinity Reference 6.5 comps in front and coaxials in the rear doors, JL 320.4 four channel, Rab Designs built ported enclosure with an SA12, Kenwood monoblock, Redline Leater shift boot/e-brake boot/center console cover, JBR short shifter/shifter bushings/rear motor mount. Build Thread 1996 Mazda Miata: Kenwood Excelon HU, Alpine speaker in the doors, Clearwater (miata specific) headrest speakers. 1994 Mazda Protege: Kenwood Excelon HU, Infinity Reference 2 ways all around, 2x RF Punch 10's in ported boxes. Link to comment Share on other sites More sharing options...
philrab Posted February 12, 2015 Report Share Posted February 12, 2015 On the other hand, you could always do an Image Dynamics or two in a sealed box, mine dropped fairly low (not 20 hz low though, not the ID8, perhaps a larger ID sub) in a really small sealed box. 2015 Toyota Tacoma Build Thread 2007 Mazda 3; 5000K HID's, Kenwood Excelon KDC-X997, Infinity Reference 6.5 comps in front and coaxials in the rear doors, JL 320.4 four channel, Rab Designs built ported enclosure with an SA12, Kenwood monoblock, Redline Leater shift boot/e-brake boot/center console cover, JBR short shifter/shifter bushings/rear motor mount. Build Thread 1996 Mazda Miata: Kenwood Excelon HU, Alpine speaker in the doors, Clearwater (miata specific) headrest speakers. 1994 Mazda Protege: Kenwood Excelon HU, Infinity Reference 2 ways all around, 2x RF Punch 10's in ported boxes. Link to comment Share on other sites More sharing options...
aculous Posted February 12, 2015 Report Share Posted February 12, 2015 Theres a ton, what type of enclosure are you looking for and what are the dimensions? I know you said 2.5cu ft but is there a limit on Width Depth Length? I'll make a list and send it over to you. Me and Trit were going back and forth about 10s and 8s and I was looking for lower end extension too. Link to comment Share on other sites More sharing options...
bigsausagepizza Posted February 12, 2015 Author Report Share Posted February 12, 2015 The space I have is 14"H x 42" W x 30" D, but I do not want to use all of it. I'm planning on a standard ported box, with low tuning of course. Looking for a fairly flat response or even a slight peak down low. 2008 Subaru WRX STI K&N Typhoon Intake Invidia Polished Stainless 3" turbo back with cat Cobb Accessport Dyno tune from Kaizen Tuning 320awhp 330ft-lb awtq MTX 421D Sub amp American Bass SQ900 Highs/Mids amp Sundown Audio SD-2 10 D4 JL Audio XR653-CS 3-way Components 3sixty.2 Second Skin Damplifier Pro Custom fiberglass wheel well enclosure Transmission Line quasi-floor enclosure http://www.stevemeadedesigns.com/board/forum/13-member-rides-builds-show-off-your-whip-show-off-your-system/ Bill Fitzmaurice TLAH line-array hifi towers 9 Goldwood 4" mids (each) 12 Goldwood 1/2" tweeters (each) NAD 1020 Preamp MiniDSP 2x4 Balanced processor Thorens TD166mkII Turntable Hafler DH-200 Amplifier http://www.stevemeadedesigns.com/board/topic/192638-line-array-hifi-tower-build/ https://www.facebook.com/HolyMountainGlass Link to comment Share on other sites More sharing options...
bigsausagepizza Posted February 12, 2015 Author Report Share Posted February 12, 2015 The DSS Ethos 12 looks like a possible candidate. 1.5 cu ft tuned to 32 is their suggestion, looks pretty good in winisd. 2008 Subaru WRX STI K&N Typhoon Intake Invidia Polished Stainless 3" turbo back with cat Cobb Accessport Dyno tune from Kaizen Tuning 320awhp 330ft-lb awtq MTX 421D Sub amp American Bass SQ900 Highs/Mids amp Sundown Audio SD-2 10 D4 JL Audio XR653-CS 3-way Components 3sixty.2 Second Skin Damplifier Pro Custom fiberglass wheel well enclosure Transmission Line quasi-floor enclosure http://www.stevemeadedesigns.com/board/forum/13-member-rides-builds-show-off-your-whip-show-off-your-system/ Bill Fitzmaurice TLAH line-array hifi towers 9 Goldwood 4" mids (each) 12 Goldwood 1/2" tweeters (each) NAD 1020 Preamp MiniDSP 2x4 Balanced processor Thorens TD166mkII Turntable Hafler DH-200 Amplifier http://www.stevemeadedesigns.com/board/topic/192638-line-array-hifi-tower-build/ https://www.facebook.com/HolyMountainGlass Link to comment Share on other sites More sharing options...
khinds94 Posted February 12, 2015 Report Share Posted February 12, 2015 zv4. Just threw on 21 hz port in a 2.5 cu box. Definitely digs. your going to need to go small on port to get the length though. 03 Sable LS AA mayhem 12" D2 Sundown ZV4 12" D1 Tantric HD 12" D2 Tantric SHD 12" D1 Sundown X12 V2 D2 2.5 cu net Sundown 2000d @ 1 ohm XS Power XP2000 Sky High Sound Deadener Sky High wire Stock alt Link to comment Share on other sites More sharing options...
bigsausagepizza Posted February 12, 2015 Author Report Share Posted February 12, 2015 zv4. Just threw on 21 hz port in a 2.5 cu box. Definitely digs. your going to need to go small on port to get the length though. I've been looking at the X-series. Small on the port is probably okay, I don't plan on pushing too much power to them and plan on doing some crazy kerfing/flaring. Considering trying the polk "power port" flow guide design to shrink the port and minimize port noise. I have access to 3D printers and would be able to print the flow guides easily. 2008 Subaru WRX STI K&N Typhoon Intake Invidia Polished Stainless 3" turbo back with cat Cobb Accessport Dyno tune from Kaizen Tuning 320awhp 330ft-lb awtq MTX 421D Sub amp American Bass SQ900 Highs/Mids amp Sundown Audio SD-2 10 D4 JL Audio XR653-CS 3-way Components 3sixty.2 Second Skin Damplifier Pro Custom fiberglass wheel well enclosure Transmission Line quasi-floor enclosure http://www.stevemeadedesigns.com/board/forum/13-member-rides-builds-show-off-your-whip-show-off-your-system/ Bill Fitzmaurice TLAH line-array hifi towers 9 Goldwood 4" mids (each) 12 Goldwood 1/2" tweeters (each) NAD 1020 Preamp MiniDSP 2x4 Balanced processor Thorens TD166mkII Turntable Hafler DH-200 Amplifier http://www.stevemeadedesigns.com/board/topic/192638-line-array-hifi-tower-build/ https://www.facebook.com/HolyMountainGlass Link to comment Share on other sites More sharing options...
Raptorman Posted February 12, 2015 Report Share Posted February 12, 2015 DSS Ethos. 1996 GMC Sonoma Four Fi BTL Neo 18's In 2:1 6th Order Bandpass 2 Ampere 5k's @ .5 TEAM FI TEAM #LITHIUMCANTDEMO On 10/20/2013 at 0:37 AM, KillaCam said: Fucking with a Prius driver is like making fun of a disabled kid. Pussies. Link to comment Share on other sites More sharing options...
khinds94 Posted February 12, 2015 Report Share Posted February 12, 2015 zv4. Just threw on 21 hz port in a 2.5 cu box. Definitely digs. your going to need to go small on port to get the length though. I've been looking at the X-series. Small on the port is probably okay, I don't plan on pushing too much power to them and plan on doing some crazy kerfing/flaring. Considering trying the polk "power port" flow guide design to shrink the port and minimize port noise. I have access to 3D printers and would be able to print the flow guides easily. Yea x would definitely be better for your power. I would do a 4 inch aero. 6 inch too big 03 Sable LS AA mayhem 12" D2 Sundown ZV4 12" D1 Tantric HD 12" D2 Tantric SHD 12" D1 Sundown X12 V2 D2 2.5 cu net Sundown 2000d @ 1 ohm XS Power XP2000 Sky High Sound Deadener Sky High wire Stock alt Link to comment Share on other sites More sharing options...
