TheUsD Posted February 20, 2015 Report Share Posted February 20, 2015 (edited) So I've been having some issues tuning two SD2-10D4s in my 02 Dodge Ram 1500. The two subs are in a sealed enclosure that fits under my seat. The enclosure is made by Atrend. Now before I go any further, I read that this site does not like/allow the comparing of subs. What I am about to say next is not to compare any two brands of subs but to help build the image of what my setup was and is now. Prior to buying the SD2's I had different subs but everything else is still the same. Subs: Two TS-W254Rs @ 2ohms with 250 RMS to each sub. Amp: GM-D8601. Gain was set to middle (turned by ear with no clipping), crossover was set between the 60hz and 125hz so I'm guessing around 90hz to 100hz H/U: AVH-X2700BS. Crossover was set a 80hz with -18db The bass sounded fantastic from the two subs, given what their capabilities were but deep down inside wanted just a little more bass. So I reached out to a few co-workers and they introduced me into Sundown. I contacted Sundown and spoke to a man name Brian who guided me from instead of purchasing two SA 10's to purchasing the SD10's given my setup. When the SD's came in the mail, I installed them but instead of having 2 ohms impedance , I wired the DVC's to a 1ohm impedance which in return raised the RMS of the am from 500RMS (250RMS per sub), up to 800x1 (400RMS per sub). Again, I tuned the subs (so they would not clip) the using the same method as I did the TS-W254R's and no matter what I did, I could not get the SD's to produce the same amount of bass as the other subs. I tried adjusting the amps crossover and the H/U's crossover for hours but could not get the volume out of the subs as others have proclaimed. I'm not sure if links are permitted so I will not post the link to a video from Sonic Electronix that uses the same method as I used to ensure the amps gain was set accordingly to keep the subs for clipping but it is a 3 part video, each part is a different method. I used video 1, the "ear" method. I do understand that the amp is pushing out 200RMS less than is should for these subs (100RMS less for each sub) but can that really make a huge difference for these subs? I can't imagine a $40 250RMS max sub would outperform a much more expensive "400RMS" sub (I would have said 500 as that's what the sub is rated but I really only have 400RMS running to each). Again, I'm not trying to compare brands by any means, I'm only trying to paint a picture of my before and after setup so that someone here might be able to help me tune these properly or at minimum point me in the right direction to some basic tuning points, aka:*Start by putting your crossover's Here, Here and Here, and the tweak accordingly* Thank you taking the time to read this and a extra "Thank you" to anyone who can help. P.S. if you require any extra info on my setup, I will be editing this post to keep the tread from being so long. Edited February 20, 2015 by TheUsD Quote Link to comment Share on other sites More sharing options...
ToNasty Posted February 20, 2015 Report Share Posted February 20, 2015 well i doubt that amp does rated power and also was the box to spec? Quote ***Super Sellers List***http://www.stevemeadedesigns.com/board/topic/25829-super-sellers-buyers Link to comment Share on other sites More sharing options...
TheUsD Posted February 20, 2015 Author Report Share Posted February 20, 2015 (edited) Sorry I did not bring this up in the first post as you reminded me with your post, ToNasty. I spoke to a few others about this amp to ensure that it was not going to under-power the subs more than, including asking Brian from Sundown, and all agreed that yes, on paper it will be producing less RMS watts than the speakers are rated for, however it should not be an issue "especially if I used good quality cabling" -Brian from Sundown, which is what I did. Again, not to compare but to help narrow down where my issue could be, I had this amp powering two TS-W3003D4 subs that are rated a 4 ohm 600RMS 2,000 peak power. This was installed in a 2013 corolla S. I ended up buying a bigger amp for the corolla just so I could match RMS as best as possible but the GM-D8601 was more than capable to power the corolla subs properly (I just wanted that little extra push, ya know? lol) The box's cu is .63 per chamber and the subs require .5. I Brought that issue up with Brian from Sundown and again, he said that would be fine as long as I used some baffling material. Luckily the box came with baffling material already installed. But just as a test to either prove or disprove your theory, ToNasty, if I was to disconnect one of the SD2s and run a single at 2ohm @500RMS, do you think that the sub would be pretty loud? Edited February 20, 2015 by TheUsD Quote Link to comment Share on other sites More sharing options...
ToNasty Posted February 20, 2015 Report Share Posted February 20, 2015 This is in a trunk? Quote ***Super Sellers List***http://www.stevemeadedesigns.com/board/topic/25829-super-sellers-buyers Link to comment Share on other sites More sharing options...
islandpride684 Posted February 20, 2015 Report Share Posted February 20, 2015 Are you comparing how it sounded when the pioneers where in the trunk to the SDs being under the seat? Quote Build Log http://www.stevemeadedesigns.com/board/topic/186921-blk9te-07-yukon-slo-mo-build/page-3?hl=%2Bblk9te#entry2881410 Link to comment Share on other sites More sharing options...
TheUsD Posted February 20, 2015 Author Report Share Posted February 20, 2015 (edited) ToNasty, the SD2 are under the rear seats of the truck. The bottom of the seats can be lifted to expose the subs but makes very little difference in sound lifted or down in the seating position. IslandPride, the subs that were in the trunk of the corolla are different size and model of the subs that were in the truck prior to installing SD2s. I was using the corolla as an example only to demonstrate the output power of the amp. My apologies if I made that a little confusing. I'll take some pictures of the setup tomorrow. Edited February 20, 2015 by TheUsD Quote Link to comment Share on other sites More sharing options...
ToNasty Posted February 20, 2015 Report Share Posted February 20, 2015 Up firing or down firing? I prefer down firing Quote ***Super Sellers List***http://www.stevemeadedesigns.com/board/topic/25829-super-sellers-buyers Link to comment Share on other sites More sharing options...
TheUsD Posted February 20, 2015 Author Report Share Posted February 20, 2015 Cones are facing up. Quote Link to comment Share on other sites More sharing options...
TheUsD Posted February 24, 2015 Author Report Share Posted February 24, 2015 (edited) Update: I swapped amps from the corolla with my truck. Going from a GM-D8601 that pushed 800RMSx1 @ 1ohm stable to: GM-D9601 that is pushing 1200RMSx1 @ 1ohm stable. That made a little improvement but I still do not fee like the subs are producing what they could be. Any suggestions? Anyone? Could my process of tuning be incorrect? I am using the 40hz Shine test tone. It is being played from my phone via Bluetooth streaming. Before playing the test tone, set my H/U to volume 25 (full is 40 and setting to 30 just seems too loud for the speakers) I ensured that the crossover on the H/U is off, and the amp's LPF is turned all the way down to 40hz. From there, I set the gain accordingly. When adjusting the amps LPF 80hz to 100hz seems to make the subs respond the best. At the H/U side, I try to match as best as possible. It seems that 80hz with -18db sounds the best for these subs but their "loudness" lacks. Is there a better way to go about this? Edited February 24, 2015 by TheUsD Quote Link to comment Share on other sites More sharing options...
islandpride684 Posted February 24, 2015 Report Share Posted February 24, 2015 Update: I swapped amps from the corolla with my truck. Going from a GM-D8601 that pushed 800RMSx1 @ 1ohm stable to: GM-D9601 that is pushing 1200RMSx1 @ 1ohm stable. That made a little improvement but I still do not fee like the subs are producing what they could be. Any suggestions? Anyone? Could my process of tuning be incorrect? I am using the 40hz Shine test tone. It is being played from my phone via Bluetooth streaming. Before playing the test tone, set my H/U to volume 25 (full is 40 and setting to 30 just seems too loud for the speakers) I ensured that the crossover on the H/U is off, and the amp's LPF is turned all the way down to 40hz. From there, I set the gain accordingly. When adjusting the amps LPF 80hz to 100hz seems to make the subs respond the best. At the H/U side, I try to match as best as possible. It seems that 80hz with -18db sounds the best for these subs but their "loudness" lacks. Is there a better way to go about this? What kind of sound do you expect it to produce? Quote Build Log http://www.stevemeadedesigns.com/board/topic/186921-blk9te-07-yukon-slo-mo-build/page-3?hl=%2Bblk9te#entry2881410 Link to comment Share on other sites More sharing options...
