dstnparr Posted February 22, 2015 Report Share Posted February 22, 2015 I was looking to get a sundown zv.4 18 in my 2009 ford focus. I figured out that after the displacement of the woofer and the port that I would have around 7 Cu. Ft. of usable air space. the port would be 5'' wide and tuned to 32 hz. the dimensions of the box are 40 wide, 20 tall, and 22 deep. For my amplifier, i was thinking of using an audiopipe 3000.1. I know that sundown subwoofers can take a decent amount more power than what they are rated, but I am a little concerned that this might be too much power. I think the enclosure will work well with this subwoofer but I wanted to try to get a second opinion on the forum. Let me know what you think or if there is any suggestions that would make this build even better. Thanks. Link to comment Share on other sites More sharing options...
reedal Posted February 22, 2015 Report Share Posted February 22, 2015 I'm quite sure that any reply to this thread about that amp will be that you're fine, it's not likely going to do rated. I've never ran audiopipe, but going by the common consensus and the cheap as dirt prices, it's a crap amp, and you're better off buying a better, more reliable amp. SMD Tool Map https://www.stevemeadedesigns.com/board/topic/193176-smd-tool-map-new-november-2014/ Build log https://www.stevemeadedesigns.com/board/topic/197217-reeds-03-tahoe-hat-sqaq-singer-xs-shca-cockbox-80prs/?page=32 Link to comment Share on other sites More sharing options...
Joe X Posted February 22, 2015 Report Share Posted February 22, 2015 20" tall trunk? Link to comment Share on other sites More sharing options...
conbon Posted February 23, 2015 Report Share Posted February 23, 2015 Youll be find with that amp on the zv.4. Just take it easy at first! depending on the ohm rating on the voice coil run it at the lowest then work its way up as it breaks in. 2013 Ford Focus Hatchback SE Kicker CS61234 Kicker 40CS674 Kicker KST25 Sundown Audio SA-12 D2 Rockford Fosgate t1000-1bdcp Rockford Fosgate t400-4 Audio Control LC7i Kinetik HC2000 0/1 Gauge Big 3 Upgrade Beer, babes, and bass. Link to comment Share on other sites More sharing options...
CleanSierra Posted February 23, 2015 Report Share Posted February 23, 2015 Youll be find with that amp on the zv.4. Just take it easy at first! depending on the ohm rating on the voice coil run it at the lowest then work its way up as it breaks in. ^^^What kind of suggestion is this? Run it at its lowest then with its way up add it breaks in? Go to the Sundown only page on FB, they'll have you running 2 of those Audiopipes on the Zv4 because it's indestructible. Im not the one you want to try to troll. Just a fyi for you. Link to comment Share on other sites More sharing options...
