wiring speakers
What r the specs of the amp and speakers?
On 3/28/2014 at 4:22 PM, KyLar96 said:
Its all about the music anyway..... Do a proper install, something your happy with, Fuck everyone else...... improve in time, where you can..... its not rocket science...
Tiburon build //www.stevemeadedesigns.com/board/topic/174059-97-hyundai-tiburon-build-from-ramming-to-slamming-slow-5k-build/
2000 Mountaineer build http://www.stevemeadedesigns.com/board/topic/186736-2000-mountaineer-build-from-ramming-to-slamming-part-iislow-5k-builddc-audio-americanbassxspowersingerarcaudiostingershcavideo-on-pg7/
2000 Mercury Mountaineer: Electrical:Singer 360 hairpin powdercoated white alt, Big 4 double run 1/0 SHCA OFC, 4 runs 1/0 OFC SHCA, limitless 70ah, HU: Pioneer deh80prs interiors: Skar sk85.4 on sb acoustics neo dome tweeters 2 Mmats sq4100s on 4 silver flute 8s(4ohm) SUB Stage: 3 DC5K [email protected] on 6 ascendant audio mayhem 12s d1.4s fully loaded
Are these single voice coil speakers?
You can't make an amp believe anything, it sees what you show it.
If you wire 4 voice 8 ohm coils as seen below it is a 2 ohm load. Do this for each channel on the amp if it is 2 ohm stable on each channel
Yes they are single coil.Thank you very much i was thinking i had mad a bad choice for my mid and high amps. I so how would you run the the set up i got I'm got two 10in and six 6in 8 ohm eminence and the American bass sq 3200.4 to get the max out put on the amp it has too see a 2ohm load
This website http://www.the12volt.com/caraudio/woofer_configurations.asp?Q=2&I=12#results will allow you to mess with different wiring configurations. If you have 6 8 ohm coils, 2 ohms isn't going to happen.
