Amp not working?
nathanb5533
I just connected my amplifier and it's getting power and remote power but power or protect arnt on and subs arnt playing? What could be te issue also power is getting to speaker wire?
2006 Pontiac G6 3.5L
Pioneer AVH-X5800BHS DVD Receiver
Singer 320 amp alternator
Crescendo audio hp120 battery
Crescendo audio bc3500d
Crescendo audio s550/2
Crescendo audio s1100/2
2 Sundown audio zv5 12
Rockford Fosgate 440-4D
5 cubic foot octoport tuned to 35 hz
4 crescendo audio pwx 8s
2 crescendo audio pwx 6.5
4 crescendo audio ft1 super tweeters
2 crescendo audio Symphony coaxial 6x9
Also it's been in my trunk for a month not being used in the brutal cold could int need to be warmed up?
Bad ground. Unhook ground from amp, use DMM and measure continuity from amp ground input to wherever your ground is. You want as little resistance as possible. If that's good, check the continuity of your ground wire for possible opens. If that's good, check to make sure your power wire has voltage. If that's good, check remote wire. If everything reads good, something's wrong with the amp.
Yeah I checked everything fuses power wire ground wire speaker wires remote wire everything's getting power I read that one kid was having issues when it was cold but it would turn in After 5 minutes when he restarted his car I wonder if mine will do the same its been sitting in my trunk for a month
Bench test the amp and see if it works, if it works on the bench then something else is wrong inside the car, if the amp does not power up then you know what the problem will be.
01 Ford focus ZX3
Pioneer AVH-X491BHS
PPI PC 4800.2
Morel Maximo 6.5" x2
Is there anyone who has a test bench in Maine?
  • 3 weeks later...
fixed it the fuses were blown
  • Who's Online   0 Members, 0 Anonymous, 773 Guests (See full list)
