Hello I have a 2005 buick rainier with stock Bose sound system in it , I just recently had a sub and amp installed with a bass control knob in the dash and I feel like it could pound harder when I crank up the bass it does not pound as hard as I thought it would
I have a kentwood excelon x500-1 1000w amp powering a hertz ebx 250 700w hertz 10" subwoofer
Amp settings bass boost level goes from 0 to 18 db Lpf 50 to 200. Input sensitivity min 5 to 0.2 max
I would like to know if I can crank up the amp without damaging my sub and if anyone has any settings They recommend that would be awesome
Thanks so much
Christopher
Christopher
My vehicle
http://www.stevemeadedesigns.com/board/garage/vehicle/3100-buick-rainier/?tab=images
2005 Buick Rainier CXL - Bose Premium & OnStar
Subs - P1 x 2 Ported Box
Amp - Kentwood Excelon X500-1 Mono block D amp - 1000W rms 1- Ohm 500W rms 2 ohm
Deck Kentwood BD362U
Mids / Highs - Bose Premium Sound System
YouTube Video of system
Nobody that actually knows anything will be able to tell you where to set your gains or anything else at over the internet, but we can help you get to where you need to be.
The installer of this gear, did they use an oscilloscope or a DD-1 to set your gains?
Also, does that amp have high level inputs or did they use a line out converter to send signal to the amp? LOC's are trash.
What you need to know is the maximum undistorted volume of the head unit, then the gain needs to be matched to that. Bass boost is usually a bad idea unless you only like a narrow band of bass to play well and to hell with the rest.
Where are you located at?
this is my install from my recept
excellion mono apm
hertz 10'
axxes linelevel converter/ amp turnon
axxess amp level control
iconnect wireing kit
labour
shop supplies
12g wireing
efx interconect cable gm battery post
i do no not know if they tuned it or not
Christopher
My vehicle
I think maybe you're expecting too much out of 1 10" on 500 watts.
And as rockford said we can't tell you where to set your controls too.
how do i findout the gain on my factory head unit?
Christopher
My vehicle
so should i leave the settings on the amp that they set themselfs??
Christopher
My vehicle
There is no gain on your headunit.
Yes you should leave it alone.
If the shop gave you a warranty you'll void it by touching any of that stuff.
ok i turned the bass boost back down lol it was at 3 and i bumped it up to 10 but i turned it back down... maybe i need to upgrade to 2 12''
Christopher
My vehicle
  • Who's Online   2 Members, 0 Anonymous, 1577 Guests (See full list)
