Christopher Dennis Gray Posted March 2, 2015 Author Report Share Posted March 2, 2015 it still pounds dec , when i play cd-- im getting a head unit installed in a month or 2 Christopher My vehicle http://www.stevemeadedesigns.com/board/garage/vehicle/3100-buick-rainier/?tab=images 2005 Buick Rainier CXL - Bose Premium & OnStar Subs - P1 x 2 Ported Box Amp - Kentwood Excelon X500-1 Mono block D amp - 1000W rms 1- Ohm 500W rms 2 ohm Deck Kentwood BD362U Mids / Highs - Bose Premium Sound System YouTube Video of system Link to comment Share on other sites More sharing options...
Broke_Audio_Addict Posted March 2, 2015 Report Share Posted March 2, 2015 Yeah, and a 500W amp on OEM electrical may not even ever make 500W Most stock electrical can handle 500 watts no problem. That being said a lot of people's definition of "music" is a clipped 30 hz sine wave with some 80 IQ knuckle head grunting about committing crimes and his genitals. Link to comment Share on other sites More sharing options...
ALPINE408 Posted March 2, 2015 Report Share Posted March 2, 2015 Stock Bose sound If the car has a stock amp and you put a hi low converter after the amp your going to have problems Have you ever had your woofers blown? Link to comment Share on other sites More sharing options...
rockFord_Expedition Posted March 2, 2015 Report Share Posted March 2, 2015 Yeah, and a 500W amp on OEM electrical may not even ever make 500W Most stock electrical can handle 500 watts no problem. Yes it can but I mean bone stock as in most shops don't do big 3, and all of that. Not saying it's an overload on the electrical. Old School/New School RF Build March 2015 SOTM Winner How to crimp large wire Link to comment Share on other sites More sharing options...
TexasRam Posted March 4, 2015 Report Share Posted March 4, 2015 Nobody that actually knows anything will be able to tell you where to set your gains or anything else at over the internet, but we can help you get to where you need to be. The installer of this gear, did they use an oscilloscope or a DD-1 to set your gains? Also, does that amp have high level inputs or did they use a line out converter to send signal to the amp? LOC's are trash. What you need to know is the maximum undistorted volume of the head unit, then the gain needs to be matched to that. Bass boost is usually a bad idea unless you only like a narrow band of bass to play well and to hell with the rest. Where are you located at? take the max number the headunit's volume goes up to and multiply by .75 This gives you the volume setting to use when setting gains 2010 Ram 1500, Pioneer deh80prs,2-12" RE SXXv2's downfired in vinal wrapped center console box, kenwood 6x9's in the doors on a mtx 4 channel, viper 5901, big 3, kinetik 2000 Link to comment Share on other sites More sharing options...
n8ball2013 Posted March 4, 2015 Report Share Posted March 4, 2015 No it doesn't. That is terrible advice and has no basis at all THERE IS NO BUILD LOG! 1998 Chevy Silverado ext cab Alpine CDA-9887 4 Team Fi 15s 2 Ampere Audio TFE 8.0 2 Ampere Audio 150.4 3 Digital Designs CS6.5 component sets Dual Mechman 370XP Elite alternators inbound! 8 XS Power d3400 6 XS power d680 Second Skin Stinger Tsunami Wiring Sky High A Real Voltmeter not a piece of shit stinger. Link to comment Share on other sites More sharing options...
rockFord_Expedition Posted March 4, 2015 Report Share Posted March 4, 2015 Nobody that actually knows anything will be able to tell you where to set your gains or anything else at over the internet, but we can help you get to where you need to be. The installer of this gear, did they use an oscilloscope or a DD-1 to set your gains? Also, does that amp have high level inputs or did they use a line out converter to send signal to the amp? LOC's are trash. What you need to know is the maximum undistorted volume of the head unit, then the gain needs to be matched to that. Bass boost is usually a bad idea unless you only like a narrow band of bass to play well and to hell with the rest. Where are you located at? take the max number the headunit's volume goes up to and multiply by .75 This gives you the volume setting to use when setting gains That sir, is quote worthy. Old School/New School RF Build March 2015 SOTM Winner How to crimp large wire Link to comment Share on other sites More sharing options...
TexasRam Posted March 4, 2015 Report Share Posted March 4, 2015 Stock Bose sound If the car has a stock amp and you put a hi low converter after the amp your going to have problems the only issue you would have is if you put the loc on the mids and highs that dont produce the sub-80 hert signals 2010 Ram 1500, Pioneer deh80prs,2-12" RE SXXv2's downfired in vinal wrapped center console box, kenwood 6x9's in the doors on a mtx 4 channel, viper 5901, big 3, kinetik 2000 Link to comment Share on other sites More sharing options...
rockFord_Expedition Posted March 4, 2015 Report Share Posted March 4, 2015 Nobody that actually knows anything will be able to tell you where to set your gains or anything else at over the internet, but we can help you get to where you need to be. The installer of this gear, did they use an oscilloscope or a DD-1 to set your gains? Also, does that amp have high level inputs or did they use a line out converter to send signal to the amp? LOC's are trash. What you need to know is the maximum undistorted volume of the head unit, then the gain needs to be matched to that. Bass boost is usually a bad idea unless you only like a narrow band of bass to play well and to hell with the rest. Where are you located at? take the max number the headunit's volume goes up to and multiply by .75 This gives you the volume setting to use when setting gains Damn so even though my DD-1 says my HU is clean all the way to 40/40 I should only go to 30 since that's what you say to do? Old School/New School RF Build March 2015 SOTM Winner How to crimp large wire Link to comment Share on other sites More sharing options...
n8ball2013 Posted March 4, 2015 Report Share Posted March 4, 2015 Stock Bose sound If the car has a stock amp and you put a hi low converter after the amp your going to have problems the only issue you would have is if you put the loc on the mids and highs that dont produce the sub-80 hert signals Another incorrect statement THERE IS NO BUILD LOG! 1998 Chevy Silverado ext cab Alpine CDA-9887 4 Team Fi 15s 2 Ampere Audio TFE 8.0 2 Ampere Audio 150.4 3 Digital Designs CS6.5 component sets Dual Mechman 370XP Elite alternators inbound! 8 XS Power d3400 6 XS power d680 Second Skin Stinger Tsunami Wiring Sky High A Real Voltmeter not a piece of shit stinger. Link to comment Share on other sites More sharing options...
