Ground Zero Subwoofers
jeepbass1
I have been looking at ground zero subs for a while now and finally contacted a dealer....
Basically I need to choose between 2 of The GZ subs...
GZPW 15Limited (around 950 each)
http://www.ground-zero-audio.com/en/products/subwooferchassis/gzpw-15limited.html
Fs 35.6hz
Qms 4.64
Qes .43
Qts .39
VAS 1.78 cuft
Mms 363.9 grams
Xmax 2.36" 1 way
Spl 95db/m
GZNW 15XSPL 15 ( around 650 each)
http://www.ground-zero-audio.com/en/products/subwooferchassis/gznw-15xspl141114110859.html
Fs 39hz
Qms 6.33
Qes .63
Qts .57
VAS 1.69
Mms 317.6
Xmax 2" 1 way
Spl 94db/m
Which sub would benefit me the most Daily on music?
The amps that will be powering these subs are 2 DD M2B's @.5 ohm per amp
Box is tuned at 28 hz atm and is aprox 7 cuft.....
Link to build....
http://www.stevemeadedesigns.com/board/topic/174595-lifted-jeep-1471db-updates-pg-5-im-so-lazy-lmao-22214/
i say the Nuclear is more for daily..and get the lows like a champ...loved mine till it was alright...
the plutonium series need a LOT of power just to get the same exact result than the nuclear...+ the plutonium series like more or less higher notes or anything upper than 34hz..
not trying to bash anything or your choice...but as far as a Nuclear has a New line of them subs...i would chose them rather than anything else..
2010 Chevrolet Cruze
Radio --- pioneer mvh-200vbt
Front/back --- alpine type s 6.5"
Sub Control --- Pac LC1
Sub Amp --- GZPA 1.4K
Sub --- GZNW 15XSPL D1
Battery - GZBP 12.2500X
pic of my nuclear..after repairs..sorround started ripping but because of my fault
I say get GZPW 15Limited because it has a 4" VC. Or just flip a coin. Both subs should put in some serious work.
Do you have a build log? Sub looks like a champ.... i will have to decide on what I want....
as said...despite the plutonium that has a 4inch VC it needs a lot power just to get it moving properly...and the get some result...
the Nuclear has a 3inch one but gets easily on the low note an with authority...i still have it in my car currently having on a M1b on 2 ohms..
Plutonium. Higher Xmax, lower Fs, higher efficiency.
"Clipping" is the biggest forum boner now. It's like witchcraft... it automatically explains just about everything people don't understand.
My build log: http://www.stevemeadedesigns.com/board/topic/200295-gckless-2011-chevrolet-impala/
High resolution photos: Gilbert Kless Photography
  • Who's Online   0 Members, 0 Anonymous, 816 Guests (See full list)
