2,000 watts to play with, what subwoofer for daily driver ?
I'm getting a 270A alternator, XS D3400 battery under the hood and big three wiring along with a proper 2K amp.
What options does sundown have for 2,000 watts as a daily driver ? I did some research and it seems like anything above the SA series is a lowend monster which I can't pull off (don't have dedicated mids so the cuttoff will be too large).
Does sundown offer anything (possibly custom) that I can use as a daily driver in the 2,000 watt range ?
The Zv4 is 1750wrms, which will take 2kw all day long.... or you can get the NSv3 which is rated for 2500wrms, but can take a good amount more.
For daily, and your power, I would probably get the Zv4.
Is the Zv4 well rounded ? I was looking at the X series but a dealer told me that it murders the lows but doesn't offer much in the midbass area (40-60hz) which would result in a huge cutoff from my components to substage.
If the Zv4 is more well rounded then that would be good (my previous sub was sundown and I wouldn't mind staying with them if the price isn't too bad).
zv4's and x's sound the same. with that power I would go with the zv4. My van plays 8-60 hz and has no problems in the 40-60 range
*** SuperSeller Status Verified *** ( http://www.stevemeadedesigns.com/board/topic/25829-super-sellers-buyers/ )
"kevosinn's" astro van
8 custom Sundown Zv4 18's
4 Sundown scv 6000's
CNF Distribution CNC parts
Skyhigh wire
some batteries
SMD Meters and tools used on the install
http://www.stevemeadedesigns.com/board/topic/172877-kevosinns-vanwest-coast-skyhigh-car-audio-vehicle/
16,000 watt walled silverado build.
http://www.stevemeadedesigns.com/board/topic/161965-walled-silverado-4-hdc4-15s-4-crescendo-3500s-and-much-more/
8,000 watt 1999 Subaru legacy outback. Build log here: http://www.stevemead...ru/page__st__60
TEAM CNF Distribution
Your build will depend on how well built you box is. The reason is impedance rise. A 2000w amp will underpower a zv4 unless you have completely no rise. So perfect sub to match that amp would be the X series. Though you could also get the zv4 then work on building an efficient box. So if you gat space get the zv4
Vw Polo
Pioneer Deh-6050UB
Sundown Saz-3500d
DD Audio 9500 15''
5.5 cubic feet box with 10 inch port @ 38hz
I live to hear the Bass drop!!!
Sounds like your dealer doesn't know what he is talking about.... What a sub can do is important, but what will make or break what it can do in your vehicle will be the box design.
Edited by ChevyBoy95
I have a pair of sa12s in a ram designed enclosure built by a local audio tuned to 31 hz with a 6 inch aero...subs up port firing to the driver side wheel well in the back of my 03 svt focus and they're running off an saz2500 at 1 ohm and they slam the lows hard and play well at least up into the 50-60 hz range havent really tested a lot above that as I've been locked into decaf since I figured out how awesome it is lol. Idk if you are set on a single sub but a pair of sa series subs would be great for what you are looking for it seems. Don't cheap out on your electrical system or your enclosure they make a huge difference in how your equipment will perform. My sas take my sundown 2500 with ease....just make sure gains are set right with a dd1 or oscope and you are golden. Anyone who thinks SAS can't handle 2000-2500 RMS daily hasn't ever used them or tried them. My gains are set properly with my dd1 and I also keep an eye on my clipping light on my bass knob as well just to be safe....I've slammed decaf full tilt for 30-45 min or more straight and the subs barely get warm at all nowhere near hot they're barely above ambient temperature as the most. Just something to think about. I also think a single x would do well in a good box if that would better fit your needs
  • 3 weeks later...
This thread answered my question for me.
I bought a SCV-2000D to run the X10v2 i should be getting in the next couple of weeks.
Running it in the specified box (1.5 net vol., 24in port area, tuned 32hz)
'07 Ford Ranger - DM-608 I E700.4 I SA-CX6.5 v2 I SAZ-1500D 15th (x2) I Zv6 12" D1 I SB500-34 I JP40 I
On 5/21/2015 at 7:07 PM, boom50cal said:
of course he gives no fucks. it's a ford ranger.
only bad mother fuckers drive ford rangers
I've got my SAZ-2000D running my Zv4 12 in a 2.75 cubic foot box (net) @ 31hz.
Sounds awesome and pounds between 25hz - 40hz but will still play up to 50hz it just not very loud compared to say 30hz.
Syphlyns 2000 F150 4.6L V8
H/U: Kendwood KDC-X898
Speakers: 4 x Alpine SPR-68 Speakers
4 Channel Amp: Alpine PDX-F4
Sub: Sundown Zv4 12
Sub Amp: Sundown SAZ-2000D
Box: 2.75 Cu Ft @ 31Hz
Alternator: Mechman 250A elite series
Wiring: All KnuKoncepz 0 gauge OFC + KnuKonceptz Krystal RCAs
  • Who's Online   0 Members, 0 Anonymous, 1627 Guests (See full list)
