sundown scv 1500 worth it to upgrade?
i wouldn't change it.. its basically the same amp.. the only difference is that the saz1200 d can put out more at higher voltage and the scv line can only see 15. something volts
i love sundown amps but i just think its a selling trick jacob is using.. make the amps put out the same watts and rate them higher to make them look cheap per watt when in fact you are getting same amp with different components to make them 12v.. not bashing on him or sundown i will still run sundown amps
What's the trick miguel?
More watts at less voltage sounds good too me.
They are cheaper too so I'm failing to see the issue.
i posted about it on another thread but looks like it was deleted
i wouldnt call changing from a saz1200 to a svc1500 an upgrade.. they put up the same numbers at 12v. if he wants to upgrade the svc2000 would be an upgrade
The scv 2000 would be awesome but I can't fit a larger size due to space on how my install is... If the scv line can put out more wattage with less voltage going with the scv 1500 I should get more wattage correct? But would that wattage even be noticeable?
what is your voltage looking like? you can get more out of that saz1200 with a better alt and a battery in the rear. even if you get the svc2000 you wont see much gains because your electrical is limited
  • Who's Online   0 Members, 0 Anonymous, 1161 Guests (See full list)
