1 xs d3100 or 2 optima d34
Im working on a system build, 4-Hdc4 15s in a wall, im running a single 300amp alt but need to work on my battery bank, i know the xs batteries are "the best" but at almost 300 i can get 2 of the optima d34 batteries and that also adds up to a larger AH resevoir. I will be running 2 3500's so im either thinking 3 of the xspower 3100's or 6 of the optima D34's..... any veiws or thoughts, space is not an issue, and personally id like the looks 6 batts in the trunk, but a stong electrical comes before looks. This IS going in my daily driver, and i love listening to loud music and showing off.
As someone who has ran optima if you can afford xs there is no comparison
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
I should be able to. My budget for the system is $5000. But thats for EVERYTHING. I plan to run 4 HDC4-15's in a 16.75ft^3 box tuned at 36hz port will be 270in^2 an 20inches deep. plan to run 2 sq4500's strapped at 2ohms (just under 10krms) i have a 300A alt, but i might need a 2nd. if i go with xs3100's ill have 6 in the back and a smaller under the hood. Pwx mids with ft1 tweets.
XS power all day worth the extra money. You get what you pay for. Make sure you get a good charger for your batteries.
On 3/28/2014 at 4:22 PM, KyLar96 said:
Its all about the music anyway..... Do a proper install, something your happy with, Fuck everyone else...... improve in time, where you can..... its not rocket science...
Tiburon build //www.stevemeadedesigns.com/board/topic/174059-97-hyundai-tiburon-build-from-ramming-to-slamming-slow-5k-build/
2000 Mountaineer build http://www.stevemeadedesigns.com/board/topic/186736-2000-mountaineer-build-from-ramming-to-slamming-part-iislow-5k-builddc-audio-americanbassxspowersingerarcaudiostingershcavideo-on-pg7/
2000 Mercury Mountaineer: Electrical:Singer 360 hairpin powdercoated white alt, Big 4 double run 1/0 SHCA OFC, 4 runs 1/0 OFC SHCA, limitless 70ah, HU: Pioneer deh80prs interiors: Skar sk85.4 on sb acoustics neo dome tweeters 2 Mmats sq4100s on 4 silver flute 8s(4ohm) SUB Stage: 3 DC5K [email protected] on 6 ascendant audio mayhem 12s d1.4s fully loaded
It's good to top them off I do mine a couple times a week with my ctkek 7002 and I have a dd that I'm running 5k on 4 abxfls non walled ported 34hz and I have d3400 upfront and 2 d3100s in the back singer 340 alt and big 4 double run 1/0 and 3 runs 1/0 all ofc with frame grounds. Rest of my electrical is in my Sig
sorry big 4... ive only heard of the big 3? explain please
Battery to frame, engine to frame or battery negative, Altenator positive to battery, alternator ground to frame or battery negative. Then ground everything to frame or if unibody strut tower.
