Zendejas Posted March 31, 2015 Report Share Posted March 31, 2015 Long time reader First time Poster.I have a 2010 Altima Currently have 2 Alpine Type R 12's. Was in a rush so bought a ported box. Bass sounds off so would like a custom cox. What would be the best specs for a box. Box Builder need Central California Area. Link to comment Share on other sites More sharing options...
Shenker Posted April 1, 2015 Report Share Posted April 1, 2015 cant build one for you but the 12s sound best around 2 cubes per woofer, 14-15 port area/cube, ported around 35-37hz at rated power (1000w), and they will do pretty good, im a big fan of type r's myself. Here's a link to one I built for 2 12s last fall, port area was a little low but it never choked it off, just could have been more. it was tuned at 32 however, it sounded great! -If its loud, fast, outrageous, or all of the above, chances are i'll think its awesome. -"No way he's OCD." -said none of the people that know me ever. 04' Suburban "Lucifer" A.K.A #Lucii (Under Construction) 4 10s on 4kW in 6cu net @~28hz /////Alpine Crescendo KnuKoncepts Optima SHCA Build Thread 92' JDM 325i "Stella" ~Going for sale to build a 350+hp E30~ Gutted pipes 96,000 OG KM's (59,000 mi) -System Removed- 1 10 on 1kW 89' Gen 3 Honda Prelude SI AWS "Odis" Bone Stock Possibly going to stance it Link to comment Share on other sites More sharing options...
Joe X Posted April 1, 2015 Report Share Posted April 1, 2015 Here is one spec for two current generation SWR-12D4 Alpine type Rs, subs/ port forwards / backwards, need to verify dimensions are good for your vehicle, power: to sub(s) rated, amp subsonic filter to 28Hz, minimum port clearance 4 1/4", figure is just an assembly guide:NOTE: If building outside you need to build a cardboard dummy box to test fit in it's way inside. Link to comment Share on other sites More sharing options...
Jeremie Dufresne Posted April 1, 2015 Report Share Posted April 1, 2015 How many cubes is the box? Link to comment Share on other sites More sharing options...
Triticum Agricolam Posted April 1, 2015 Report Share Posted April 1, 2015 How many cubes is the box? Vb = 3.5 ft^3 "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds: Link to comment Share on other sites More sharing options...
Joe X Posted April 1, 2015 Report Share Posted April 1, 2015 The above is meant to work with the new 5th generation type Rs the older ones will work in 2 cubes net per driver. Link to comment Share on other sites More sharing options...
Zendejas Posted April 1, 2015 Author Report Share Posted April 1, 2015 cant build one for you but the 12s sound best around 2 cubes per woofer, 14-15 port area/cube, ported around 35-37hz at rated power (1000w), and they will do pretty good, im a big fan of type r's myself. Here's a link to one I built for 2 12s last fall, port area was a little low but it never choked it off, just could have been more. it was tuned at 32 however, it sounded great! Will check it out Bro..... Link to comment Share on other sites More sharing options...
Zendejas Posted April 1, 2015 Author Report Share Posted April 1, 2015 Here is one spec for two current generation SWR-12D4 Alpine type Rs, subs/ port forwards / backwards, need to verify dimensions are good for your vehicle, power: to sub(s) rated, amp subsonic filter to 28Hz, minimum port clearance 4 1/4", figure is just an assembly guide: NOTE: If building outside you need to build a cardboard dummy box to test fit in it's way inside. They are the current Generation Type R. Will attempt to build this box over this weekend. My first box let see how this goes. Link to comment Share on other sites More sharing options...
Zendejas Posted April 1, 2015 Author Report Share Posted April 1, 2015 I believe this is the box i currently have now it was 25$ bucks cant complain... GroundShaker SQP212B SpecificationsPART # : CONSTRUCTION : 3/4, 11/16" MDF VOLUME : 2.65 CU.FT. WEIGHT : 50 LBS. M / DEPTH : 13 1/2" DIMENSIONS: HEIGHT : 13 1/2" LENGHT : 33 1/2" DEPTH : 17 1/2" Featured- INDIVIDUAL CHAMBERS Link to comment Share on other sites More sharing options...
Zendejas Posted April 2, 2015 Author Report Share Posted April 2, 2015 Would it aound better in a 6Th Order Link to comment Share on other sites More sharing options...
