Gingeriffik Posted April 3, 2015 Report Share Posted April 3, 2015 What would the total RMS output be running the 2 1.2k's linked? And would it be safe to run it set up that way at 1.5ohm ( 2 dual 6ohm subs (JBL GTi's))? Quote <>< Collosians 2:13-14, Philippians 4:13, 1 John 4:7-10 2 - JBL W15Gti 2 - JBL BP1200.1 Knu 1/0 Wiring Kenwood KIV-BT901 Kenwood/Garmin Nav. Link to comment Share on other sites More sharing options...
islandpride684 Posted April 3, 2015 Report Share Posted April 3, 2015 What would the total RMS output be running the 2 1.2k's linked? And would it be safe to run it set up that way at 1.5ohm ( 2 dual 6ohm subs (JBL GTi's))? 2400 @ 2ohm strapped Quote Build Log http://www.stevemeadedesigns.com/board/topic/186921-blk9te-07-yukon-slo-mo-build/page-3?hl=%2Bblk9te#entry2881410 Link to comment Share on other sites More sharing options...
Gingeriffik Posted April 4, 2015 Author Report Share Posted April 4, 2015 1.5ohm to low? Quote <>< Collosians 2:13-14, Philippians 4:13, 1 John 4:7-10 2 - JBL W15Gti 2 - JBL BP1200.1 Knu 1/0 Wiring Kenwood KIV-BT901 Kenwood/Garmin Nav. Link to comment Share on other sites More sharing options...
islandpride684 Posted April 4, 2015 Report Share Posted April 4, 2015 (edited) 1.5ohm to low? not recommended...if you plan on going below make sure your electrical can handle it....strapped @ 1.5/each amp will see .75...best bet is to get an amp that does 3.5K @ 1ohm/1800 @ 2ohm then you can guess what it does in between at 1.5ohms.... Edited April 4, 2015 by islandpride684 Quote Build Log http://www.stevemeadedesigns.com/board/topic/186921-blk9te-07-yukon-slo-mo-build/page-3?hl=%2Bblk9te#entry2881410 Link to comment Share on other sites More sharing options...
