Tod Gumtau Posted April 18, 2015 Report Share Posted April 18, 2015 I have 1 orion h2 12.2 and due to missunderstanding 1 orion h2 12.4 it was supposed to be a h2 12.2 and i cant find a matching one for either any way to wire them to same amp if i wired just one voice coil on the 2 ohm and wired the dual 4 ohm to 2 ohm would it work Link to comment Share on other sites More sharing options...
reedal Posted April 18, 2015 Report Share Posted April 18, 2015 It will work, you can do it, but it's not recommended because the subs will not be receiving the same amounts of power, and having only one vc on the 2ohm sub wired might give that single vc too much power and fry it depending on the power output of your amplifier. But it's at your own discretion whether you do or not. Try it and let us know the results. SMD Tool Map https://www.stevemeadedesigns.com/board/topic/193176-smd-tool-map-new-november-2014/ Build log https://www.stevemeadedesigns.com/board/topic/197217-reeds-03-tahoe-hat-sqaq-singer-xs-shca-cockbox-80prs/?page=32 Link to comment Share on other sites More sharing options...
Triticum Agricolam Posted April 18, 2015 Report Share Posted April 18, 2015 Does your box have seperate chambers for each sub? No matter what you do, one sub is going to get twice the power of the other. If your box has seperate chambers your situation could be made to work, though it will be significantly less than ideal. If your box does not have seperate chambers you are completely out of luck. Regardless, the best thing to do since you can't find a matching sub, is to sell them both and buy a pair of something that does match. "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds: Link to comment Share on other sites More sharing options...
Triticum Agricolam Posted April 18, 2015 Report Share Posted April 18, 2015 Double tap.... "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds: Link to comment Share on other sites More sharing options...
Jhunt94 Posted April 18, 2015 Report Share Posted April 18, 2015 Are you asking if you can wire 3 of 4 coils together and it work?? There's a reason there's 2 voice coils on that sub, both have to be wired up for the sub to reach it's max potential. There are ways to wire both of them together but you will get an odd ohm load any way you do it and I'm sure most people will just recommend not to. Can you contact the seller that you purchased the 12.4 from and ask if they will swap it out? 2007 Ford F-150 Reg. Cab. Flareside250 Mechman AlternatorSky High Car Audio Big 3 XS Power D3400Rockford Fosgate 1/0 amp kitRockford Fosgate T1500-1bdcpRockford Fosgate T400-4DC Audio Lvl 4 12"Rockford Fosgate Punch 6.5" componentRockford Fosgate Punch 6x8Pioneer AVH-P2300DVDSMD Volt Meter Link to comment Share on other sites More sharing options...
Joe X Posted April 18, 2015 Report Share Posted April 18, 2015 I have 1 orion h2 12.2 and due to missunderstanding 1 orion h2 12.4 it was supposed to be a h2 12.2 and i cant find a matching one for either any way to wire them to same amp if i wired just one voice coil on the 2 ohm and wired the dual 4 ohm to 2 ohm would it work The sub with one coil wired is maybe good for half it's rated power and it's parameters will shift. Not really a good Idea, I would just sell both and get something different. Link to comment Share on other sites More sharing options...
Tod Gumtau Posted May 5, 2015 Author Report Share Posted May 5, 2015 ok i wired the H2.2 to 4 0hm and only 1 side of the h2.4 to 4 ohm it sounds decent in separate chambers had mark from car audio fab design me a box and he put both in same box so i found a match for the h2.4 Link to comment Share on other sites More sharing options...
JP-12 Posted May 5, 2015 Report Share Posted May 5, 2015 Why'd you even ask then lol Link to comment Share on other sites More sharing options...
Guest Posted May 5, 2015 Report Share Posted May 5, 2015 this install should last you for years to come you should do it right the first time around or you will end up breaking stuff and spending more later Link to comment Share on other sites More sharing options...
