CKRguy Posted April 19, 2015 Report Share Posted April 19, 2015 Hey everyone , here's my current setup.. 06 Tahoe I have 4 T2D215's box tuned to 34hz at first I used a single t2500bdcp wired to 1ohm for the 15s my electrical setup is a,custom built 260 amp alt 2 xspower mx,2000 batts all 0 gauge wiring the issue I'm having is when I wire up my amp and tune it correctly... Gain was at 6 of 11 x over was on 55 infrasonic filter on and all but here is what's happening the amp is getting HOT and starts smelling awful and it blew so we Got another t2500 and upgraded grounds even more and it lasted maybe 2 minutes and blew , what am I doing wrong Link to comment Share on other sites More sharing options...
SnowDrifter Posted April 19, 2015 Report Share Posted April 19, 2015 What's your voltage at the amp?Have you checked your subs for shorts? What method did you use to set you gain? How did you arrive at your setting? ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444 Link to comment Share on other sites More sharing options...
reedal Posted April 19, 2015 Report Share Posted April 19, 2015 How are you coming to "6 out of 11" with your gains? What tool are you using to set it to that point? SMD Tool Map https://www.stevemeadedesigns.com/board/topic/193176-smd-tool-map-new-november-2014/ Build log https://www.stevemeadedesigns.com/board/topic/197217-reeds-03-tahoe-hat-sqaq-singer-xs-shca-cockbox-80prs/?page=32 Link to comment Share on other sites More sharing options...
CKRguy Posted April 19, 2015 Author Report Share Posted April 19, 2015 The amp is coming straight from one of the batteries and it was reading 14v and we tuned it by ear ... And 6 out of 11 I mean that by the amps gain being a lil over half, but here's what we thought was the culprit originally , there was resistance from,grounding one of the batts that are going to my bass amp so,we upgraded it and now I have received my 3rd t2500 and we put the subs to a 4ohm load just to have bass for the mean time cause I ordered aanother bass amp to run 1 pair at A 2ohm load and the 2nd pair at 2ohms and the amp being at 4 ohms with barely any gain is still getting warm so,I'm completely lost Link to comment Share on other sites More sharing options...
SkarredSierra Posted April 19, 2015 Report Share Posted April 19, 2015 Do u not have a fuse between the amp and batt? Link to comment Share on other sites More sharing options...
CKRguy Posted April 19, 2015 Author Report Share Posted April 19, 2015 I don't have a fuse between the battery and amp, when the other 2 amps blew if you smell where power and ground and remote wires go it has no smell but smell the inputs for speaker wore it smells like ass Link to comment Share on other sites More sharing options...
CKRguy Posted April 19, 2015 Author Report Share Posted April 19, 2015 I didn't know if that info about the bad smell would help or not Link to comment Share on other sites More sharing options...
JEFFYBOI Posted April 19, 2015 Report Share Posted April 19, 2015 If voltage is stable, Then you are clipping the signal and roasting them unless something is shorting out maybe. If the amps are getting really hot that's a clear sign to your issue. "Toyota Camry rebuild page 21 (link)http://www.stevemeadedesigns.com/board/topic/183768-94-crossfire-camry-18s-walled-singer-alt-has-arrived-rebuild-starts-pg-10/page-21 PIONEER DEH-P8400BH 2 CROSSFIRE C5 1700D 2 CROSSFIRE C7 18 HOOD. NSB GROUP48 TRUNK SMS AGM400 DUAL RUNS X SCORP 1/0 OFC 275A SINGER ALT. DYNAMAT XTREME SOUNDSTREAM TA4.280 PIONEER COMPONENTS Link to comment Share on other sites More sharing options...
OrionStang Posted April 19, 2015 Report Share Posted April 19, 2015 You gotta have a short somewhere. How are your 4 subs wired? SMD Super Seller My Feedback Thread Link to comment Share on other sites More sharing options...
CKRguy Posted April 19, 2015 Author Report Share Posted April 19, 2015 How do I clip the signal if my gain is set to barley any I just can't understand it , I feel like such a newbie .... But do you guys think adding another amp would help the issue ? Link to comment Share on other sites More sharing options...
