Will That be a safe amount of power to be Blasted Daily?
Looking to order a small setup for my trunk
And box specs say .75-1.0 cu Ft for the box. Do I want more on the side of 1.0 cubes?
Without music, life would be an error
Yes for the power and 1 ft3 for the enclosure tuned around 34Hz.
Vehicle: 2013 Ford F-150 STX SuperCab 5.0L V8 4x4
BIG 3: Knukonceptz Kolossus Fleks 0 Gauge OFC Power Amp Kit
Headunit: Stock (Leaving factory look)
Speakers: Stock
Subwoofer: Incriminator Audio Lethal Injection 10" D2 wired down to 1 ohm
Enclosure: ~1.5 cubic feet tuned to ~34 Hz (Port Area ~24 inches)
Amplifier(s): Sundown Audio SAE1000.1D
Amp Power Kit: Knukonceptz Complete 4 Gauge OFC Amplifier Installation Kit
No. But you are welcome to wait for others to respond as well.
Speakers: Stock
I have, well had an SA12 on an SAE-1000d. It started on fire anytime it'd get power and then my inline fuses would pop. Not sure if it was from excessive vibration or running it at lower voltage. Either way It'll pound that sub.
Don't mount the amp to the box and make sure your voltages are above 12.4 and that'll be a good amp.
Bass head in training. Trying to learn everything I can.
2014 Dodge Dart GT
Synergy Audio WFO 15.1 V2 (Prototype)
Sundown X12
probably low voltage. SA amps some good protection circuitry.
Edit: Also TrunkMuzik. the way it usually works. If you are running more than RMS power, you go with a smaller size of the box. If you have less than RMS. You go for the bigger size box.
Edited by RooTxBeeR
  • Soon To Be
  • '04 Ford Escape
  • US Alternator 280A Hairpin
  • D4800 Under the Hood
  • (6) XP3000's in Rear
  • Pioneer DEH-80PRS
  • DD AW6.5 (2) per door
  • *Tweeter Unkown*
  • DD SS4a & C3d
  • (2) SCV4000 @ .5Ohm
  • (2) 15" Sundown Zv5
Inline fuse as in the fuse coming from my batttery. None of the fuses on the amp blew.
2014 Dodge Dart GT
Sundown X12
  • 3 weeks later...
So would .75 cu before displacement be ok? Would 800rms be a better option? Or stick with the sae-1000
You'll want .75 cu after all displacements (sub and port).
Speakers: Stock
  • Who's Online   1 Member, 0 Anonymous, 1583 Guests (See full list)
