My first amp ever was a shitty pyramid amp similar to yours, and my recommendation, get your money back and buy a real amp. As for big three, yes, when you add equipment that draws more amperage than what was intended, you should upgrade power and grounds
^^^ x2 on that
System:
Pioneer DEH-8400BH
4 Alpine Type R 6.5's
4 Soundqubed PA 6.5's
4 Soundqubed Supertweets
Hifonics BRX 640.4
Crescendo S800/4
2 Soundqubed Q1-3500.1s strapped @1ohm
2 Soundqubed HDC4 18's
11 Cubes net @37hz (Subs up, port back)
2 DC Power 250 HD's
1 DC Power 300 SPX
DC Power triple alt bracket
5 Kinetik HC 1800's
4 runs of 1/0 OFC power cables
4 runs of 1/0 OFC grounds from rear battery bank to OEM alt bracket
iPad Air in dash
300+ sq ft or sound deadening
Advantages: more current flow for the extra current draw that adding an after market sound system requires from alternator/battery
Meh...and its the subs that need to handle the amp. Clipped signal and low voltage are major factors to failed equipment, especially sub-par equipment so in your case get as many volts as you can and a big 3 would help with that, would need to for future upgrades anyway.
Headunit - Sony DSX-200X
Subs - (2) Modified American Bass 18's
Monoamp - DD M4
Front Stage - CDT HD62-AS components with
4 Crescendo PWX 6.5
4 Channel Amp - Hifonics ZRX1000.4
Cadence 0 gauge
Singer 275 amp Alt
D7500 XS Power battery
Quad 1/0 input Toolmaker terminals
SMD OM-1
RGB LEDs
BUILD LOG CURRENT ABOVE SETUP http://www.stevemeadedesigns.com/board/topic/191602-2003-bravada-2-18s-ab-dd-xs-singer/
BUILD LOG (2 MTX 7512's)http://www.stevemead...__fromsearch__1[/size]
I doubt that audiopipe is any better than the pyramid. About 25 cents per a watt is a good place to start in my book (not always). Take the rated rms power of that amp, multiply by .25, and if the price is $75 or less below that then it's definitely a waste of money. Just my opinion and way of looking at things. Doesn't necessarily speak for the actual quality. But usually things that work better cost more
I'd definitely say do the big 3.. Less stress on everything and it doesn't hurt.. It'll make a difference with what you're running.
Bass head in training. Trying to learn everything I can.
2014 Dodge Dart GT
Synergy Audio WFO 15.1 V2 (Prototype)
Sundown X12
  • Who's Online   0 Members, 0 Anonymous, 925 Guests (See full list)
