Zendejas Posted May 14, 2015 Report Share Posted May 14, 2015 I Have been look all over the SMD Forums and as well Google, And i can not find a straight answer what would be the best product for my Altima's Trunk. Damplifier Pro or Spectrum. I Was thinking Spectrum In the Trunk and Damplifier Pro On the doors. Quote Link to comment Share on other sites More sharing options...
diegoclass2010 Posted May 14, 2015 Report Share Posted May 14, 2015 they both work similar and you might get the similiar effect. i have used spectrum and love it, just apply 3 coats Quote Link to comment Share on other sites More sharing options...
Zendejas Posted May 15, 2015 Author Report Share Posted May 15, 2015 they both work similar and you might get the similiar effect. i have used spectrum and love it, just apply 3 coats Thanks bro thats the way i was leaning more to.. Just Noob question how do you spray it on just spray it were you would put Damplifire Quote Link to comment Share on other sites More sharing options...
Second Skin Posted May 15, 2015 Report Share Posted May 15, 2015 They both are designed to perform the pretty much the same, it basically comes down to preferred method of application. The peel and stick Damplifier/D Pro will have to be cut into shape while the liquid Spectrum will go on easier. One thing to watch for in the doors is not spraying/brushing Spectrum onto the window or working window parts. Great thing about Spectrum is you can spray on different thicknesses for different noise areas (i.e 1-2 coats on roof for 1-2 mm coating and 2-4 coats in high noise areas like trunks, wheel wells for a 3-4 mm coating). 1 Gal of Spectrum will cover 10sqft at the recommended 3mm thickness. Let us know if you have any other questions. Second Skin For The Win!!! Quote Whether you are restoring a classic muscle car, building an audio system monster, or trying to give yourself a bit of silent luxury on your daily commute, we have a product or combination of products that will help you achieve your goals while saving money and save time. Look around our site, educate yourself and make the choice that is right for you. Over built to over perform - because user error, bad batch, and faulty install are excuses that other companies use! Link to comment Share on other sites More sharing options...
Second Skin Posted May 15, 2015 Report Share Posted May 15, 2015 PS It can be sprayed, brushed, or rolled on and it should go on any metal you are able to spray it on in the doors/trunk. If you search Second Skin Spectrum on google or you tube you will find a lot of videos out there of the product being sprayed, here is just one video for you Quote Whether you are restoring a classic muscle car, building an audio system monster, or trying to give yourself a bit of silent luxury on your daily commute, we have a product or combination of products that will help you achieve your goals while saving money and save time. Look around our site, educate yourself and make the choice that is right for you. Over built to over perform - because user error, bad batch, and faulty install are excuses that other companies use! Link to comment Share on other sites More sharing options...
Second Skin Posted May 23, 2015 Report Share Posted May 23, 2015 Memorial Day DiscountIn remembrance of our service men and women of the past and present recieve 10% off any order $250 and over (not including shipping). Enjoy your Memorial Day weekend.Use Promo:REMEMBER10in the discount box when checking out at www.secondskinaudio.com. Quote Whether you are restoring a classic muscle car, building an audio system monster, or trying to give yourself a bit of silent luxury on your daily commute, we have a product or combination of products that will help you achieve your goals while saving money and save time. Look around our site, educate yourself and make the choice that is right for you. Over built to over perform - because user error, bad batch, and faulty install are excuses that other companies use! Link to comment Share on other sites More sharing options...
Zendejas Posted May 29, 2015 Author Report Share Posted May 29, 2015 they both work similar and you might get the similiar effect. i have used spectrum and love it, just apply 3 coats Was thinking 2 Coats but 3 should be best. Quote Link to comment Share on other sites More sharing options...
Zendejas Posted May 29, 2015 Author Report Share Posted May 29, 2015 They both are designed to perform the pretty much the same, it basically comes down to preferred method of application. The peel and stick Damplifier/D Pro will have to be cut into shape while the liquid Spectrum will go on easier. One thing to watch for in the doors is not spraying/brushing Spectrum onto the window or working window parts. Great thing about Spectrum is you can spray on different thicknesses for different noise areas (i.e 1-2 coats on roof for 1-2 mm coating and 2-4 coats in high noise areas like trunks, wheel wells for a 3-4 mm coating). 1 Gal of Spectrum will cover 10sqft at the recommended 3mm thickness. Let us know if you have any other questions. Second Skin For The Win!!! Thanks for helping out. Would it be a good idea to lay the spectrum down first then later add some Damplifer Pro or should it be the other way around. As well how many gallons would 2010 Altima trunk need would 5 Gallons be way to much or just enough. Memorial Day Discount In remembrance of our service men and women of the past and present recieve 10% off any order $250 and over (not including shipping). Enjoy your Memorial Day weekend. Use Promo: REMEMBER10 in the discount box when checking out at www.secondskinaudio.com. wish this Promo was still good didn't have funds till this weekend. Quote Link to comment Share on other sites More sharing options...
Second Skin Posted May 29, 2015 Report Share Posted May 29, 2015 (edited) If you plan on using both Spectrum and Damplifier together we would suggest using Damplifier first then adding the Spectrum on top for best results. Each gallon will cover 10sqft at the recomended 3mm thickness achieved by 2-3 coats. As far as the sale goes, sorry it is over but our next sale will be in a few weeks for the Fourth of July...keep your eye open on the forum, Facebook, Instagram, or email list. Edited May 29, 2015 by Second Skin Quote Whether you are restoring a classic muscle car, building an audio system monster, or trying to give yourself a bit of silent luxury on your daily commute, we have a product or combination of products that will help you achieve your goals while saving money and save time. Look around our site, educate yourself and make the choice that is right for you. Over built to over perform - because user error, bad batch, and faulty install are excuses that other companies use! Link to comment Share on other sites More sharing options...
