Hey guys,
I just recently got my Jeep Cherokee XJ that I will be using as a daily/off road rig. I will soon be upgrading it to a 4.5" lift on 32s, also should hopefully be getting around to making the roof rack. But with having an off roading rig I have to downgrade my system from a soundqubed 18" to some 10's. I wanted to run run a single Fi Q-12, but I had these two laying around so I decided to just use these subs instead.
I will be running:
x2 Rockford Fosgate P3D4-10
x1 Soundqubed Q1-1200
x1 Soundqubed Q4-120
x1 Pioneer DEH-80PRS Headunit
x4 Some MTX Coaxial speakers that were in the car when I bought it (I will eventually be replacing those with some kind of components)
I have all the pieces cut out here. Because of the way I am putting these in my car I decided to make two separate boxes and later make it look like one through the use of beauty panels. If I had designed it to be one single box it would have deprecated sound quality or I would have had to changed the layout inside my car. Neither of which I wanted to do.
Test fitting the box together.
Speaker hole cut out.
Gluing the box together. I did not use NEARLY enough clamps.
I let the glue set a little then replaced the clamps with some screws and this box is pretty much finished. The second box is completely identical to this one.
Playing around with some trim panel ideas. I liked this one a lot. It has a fogged plexiglass insert that can be LED it.
29447de0-a9e4-4d3a-9230-4eef840bbffa_zps
More to come!
2002 Toyota Corolla
Pioneer DEH-80PRS
Soundqubed Q1-2200d
Soundqubed HDC3.118
Soundqubed Q4-120
Alpine SPR-60
Alpine SPR-60C
Its been a while since I started working on this. I've been working a physics project for a while now (making a 2D Ruben's Tube, I get to play with fire and sound at the same time :yahoo: ) but since we ran out of flux core wire for the welder today I got a little work done on this build.
I was able to get the amp rack almost done, all I need to do after this is install the cooling fans for the amps. And put in a couple notches to run in the wires and RCAs.
Q4-120 and Q1-1200 sitting in the amp rack
Sub Boxes sitting on top of the rack. Just how they will be installed in the Jeep when I'm finished.
This is with the everything set in the Jeep. Showing how the final project will look. Now once everything is complete there will actually be drawers behind the subs, and it will look like all one big unit.
2002 Toyota Corolla
Pioneer DEH-80PRS
Soundqubed Q1-2200d
Soundqubed HDC3.118
Soundqubed Q4-120
Alpine SPR-60
Alpine SPR-60C
  • 3 weeks later...
  • Who's Online   1 Member, 0 Anonymous, 729 Guests (See full list)
