DC Sound Lab
So im going to be reconeing the lvl 3 15s i have. My first question is if i upgrade to level 4 soft parts will the power handling capabilities be the same as a level 4? If yes can i order xl recones and have the same power handling as an xl? (Obviously with less motor force?) My next question is what benefits (specifically please) does the ar cone upgrade provide and is it possible to get a picture of a 15 with the ar upgrade? Thank you
I think you can't put an XL recone on a Level 3 motor.
AS for power handling- I'm not sure if it's the same as Level 4, but I can tell you from my personal epirience that is goes up :) I can assume that the output wont be the same as level 4.
Ok I will do my best to explain this, upgrading coils spiders cones things like that will not drastically increase power handling however it does increase the thermal handling the benefit being you can now beat the ahit out of your subs for longer without worries....if you want to increase mechanical power handling this can be done by shrinking down your enclosure a smaller enclosure decreases the back pressure helping to keep the sub within its mechanical limits benefits of our ar cone it is a stronger lighter cone that allows for more travel there are kevlar fibers impregnated into the cone itself to make it a lot stronger while decreasing weight then we added a high roll surround that is over twice the thickness of our stock surround give me a call during business hours if you have any other questions 8557753299
