world27owns Posted May 24, 2015 Report Share Posted May 24, 2015 Went out to my first comp today. The highest I hit was 139.9 on a 34 hz burp. I think there might have been some major flaws in my box design looking for suggestions for another box. I am not opposed to any suggestions at this point but due to trunk size the sub will have to face upward. Just looking to get a little louder. Setup 05 Chevy Malibu 1 18 FI SP4 DC Audio 2k A3 (2000rms) Sky High Big three (2/0) OFC Sky High (1/0) OFC ran to back XS D3400 (starting) XP3000 (Rear) Box (3/4 MDF) Exterior Height 15in, Width 38in, Depth 30in Port 34hz (opening facing inside cabin on bottom of box) Height 2in, Width 36.5 in, Length 18 in The top (sub holding side) was braced with another sheet of mdf 36.5 x 28.50 The port side was also braced the same way The port itself had 2 3/4 x 3 in mdf "leg" supports in the rear When I first played it I had about 1-3 inches of flex on bottom of the box which I was able to reduce by putting in multiple 3 inch lag bolts. Link to comment Share on other sites More sharing options...
hispls Posted May 27, 2015 Report Share Posted May 27, 2015 That's not terrible for that cone area and power out of a trunk at that frequency. If you really want to get louder you must be prepared to buy an SPL meter and be ready to invest a lot of time and money into building boxes. You should post pictures of the trunk as it sits if you want some general advice. Link to comment Share on other sites More sharing options...
world27owns Posted June 1, 2015 Author Report Share Posted June 1, 2015 I have removed the old box and in the process of building a new one going with 2 6 in aero ports (planning on tuning a little higher will start with 40hz and see how that sounds and go from there). Basically same specs but chopped an inch off the height so I could actually remove the box from the trunk without having to destroy it. As I do not currently have the trunk sealed off ill see how it sounds (sub still up) port facing rear. Will post some pics of final product. Link to comment Share on other sites More sharing options...
