Bump4life Posted June 3, 2015 Report Share Posted June 3, 2015 before i came in here i knew his problem. good job on the fix. those pico fuses are bitches. Buyer/Seller Feedback Thread: http://www.stevemead...5015-bump4life/ MB C220 153 Trunk Car Build Log: http://www.stevemead...d/#entry1840136 MB C280 Ipad Dash SQ Build Log: http://www.stevemeadedesigns.com/board/topic/194484-bump4lifes-new-benz-tony-c-relay-kit-pictures-ce-electric-audison-front-stage-installed/ My SPL Log: http://www.stevemead...__fromsearch__1 BMW M340 xDrive Stock, for now. Corner Load 10" maybe soon. But does 10s in the 1/4... Best Scores out of a trunk 153.0 sealed legal full tilt clamped 5524 @ 42 hz 154+ windows down, 155+ kick Link to comment Share on other sites More sharing options...
MrSkippyJ Posted June 3, 2015 Report Share Posted June 3, 2015 no. pioneer is fine. it's only when people unplug and plug in rcas when the headunit is on. causing a very tiny "pico" fuse to blow, which is what probably caused your issue With you on this. I have never had an issue with RCAs on any of pioneer units. F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69 Link to comment Share on other sites More sharing options...
reedal Posted June 3, 2015 Report Share Posted June 3, 2015 no. pioneer is fine. it's only when people unplug and plug in rcas when the headunit is on. causing a very tiny "pico" fuse to blow, which is what probably caused your issueWith you on this. I have never had an issue with RCAs on any of pioneer units. Never had a grounding issue with mine either. OP, Pulling an RCA with voltage going through it is asking for a short (no matter what head unit). Only connect/disconnect RCA's with the car & head unit off to avoid future problems. And anything else that carries voltage SMD Tool Map https://www.stevemeadedesigns.com/board/topic/193176-smd-tool-map-new-november-2014/ Build log https://www.stevemeadedesigns.com/board/topic/197217-reeds-03-tahoe-hat-sqaq-singer-xs-shca-cockbox-80prs/?page=32 Link to comment Share on other sites More sharing options...
Ryan1994Wright Posted June 4, 2015 Author Report Share Posted June 4, 2015 Yeah that is what I've been told is the Pico Fuses blow. Link to comment Share on other sites More sharing options...
