jcarter1885 Posted June 3, 2015 Report Share Posted June 3, 2015 Nice grab on the Tahoe Nav-TV Zen V Audio Interface AudioControl DM-608 (2) Stevens Audio Neo-Comp Full-Size Horns (4) Faital Pro 6PR160 6.5" AudioControl LC-6.1200 (1) Fi Neo 4.7 15" D2 in 3.74 Cubic Feet @ 27.70 Hz Ampere Audio AA3800.1 Odyssey ODP-AGM48 Battery (Starting) Odyssey ODX-AGM31 Battery (Trunk) Big 3 - 2\0 Welding Cable, KnuKonceptz Speaker Wire & 1/0 Power Cable, NVX RCAs, Second Skin (Speaker Tweaker Pads, Damplifier Pro Mat), Diode Dynamics LEDs Link to comment Share on other sites More sharing options...
Second Skin Posted June 3, 2015 Report Share Posted June 3, 2015 Nice Work Whether you are restoring a classic muscle car, building an audio system monster, or trying to give yourself a bit of silent luxury on your daily commute, we have a product or combination of products that will help you achieve your goals while saving money and save time. Look around our site, educate yourself and make the choice that is right for you. Over built to over perform - because user error, bad batch, and faulty install are excuses that other companies use! Link to comment Share on other sites More sharing options...
UB6-IB9 Posted June 4, 2015 Author Report Share Posted June 4, 2015 So next step was to build my pods for my tweeters and my 3" rounds. I decided to put the 3" in my I pillars and my tweeters behind my mirrors. Unfortunately i didnt take as many pics as i wanted due to the constant mess of filling and sanding. Running wires for my 3" Mounting rings at angles i want Dowels for support Now we don't get to see the 5-6+ hours on each pod in filling and sanding or even my fiber glassing. I also had a hell of a time trying to wrap these so i just sprayed them with bed liner instead. I am super happy how they turned out though, they are nice little sealed chambers. I will post more pics of them but my Tahoe is getting the ignition module changed so i dont get it back till tomorrow. Now for my tweeter pods. I wrapped my plastic in tape then fiberglassed over them then mounted the tweeters mounting ring then fiberglassed over them. Again hours and hours of filling and sanding but i couldnt wrap these nicely as well so i also sprayed these with boxliner. Base fiberglass piece Finished product. I will post more pics of these Link to comment Share on other sites More sharing options...
UB6-IB9 Posted June 4, 2015 Author Report Share Posted June 4, 2015 Then my carpet came for my box so i could carpet it At first my plan was to mount my amps under my sub box and have them on rollers to roll out but then i realized that they couldn't roll out far enough to have access to all them so i decided to mount them at the same angle as my rear seats and have it join the front of my sub box. The wood cut for the top and bottom of my amp rack This is how i had them in my plan to have them roll out from under box The xdi amp and the ps8 have blue lights on them so i am considering adding in blue leds inside my rack and depending on heat i will add fans Rack with the top piece test fit as well. It is now carpeted I had to put the sub box in without the subs cause the 76lbs each sub makes that one heavy box Amp rack mounted in place. I havent put the front on cause i will be accessing the amps setting and hooking my laptop up to the PS8 Now my new Singer alternator arrives today and hopefully i get the Tahoe back today so i can hook up my alt and my dual batteries under the hood Link to comment Share on other sites More sharing options...
UB6-IB9 Posted June 5, 2015 Author Report Share Posted June 5, 2015 Got some mail today All 270 amps of sexyness I have nothing but great things to say about dealing with Mike. We traded 12-15 emails back and forth, great customer service, quality product. I won't buy an alternator anywhere else that's for sure w Link to comment Share on other sites More sharing options...
UB6-IB9 Posted June 5, 2015 Author Report Share Posted June 5, 2015 w Sorry for double pic post Link to comment Share on other sites More sharing options...
UB6-IB9 Posted June 5, 2015 Author Report Share Posted June 5, 2015 Link to comment Share on other sites More sharing options...
scooter99 Posted June 5, 2015 Report Share Posted June 5, 2015 Nice start. Yes Mike's customer service is second to none. Quick responses, accurate information, little things like your note there about belts and grounds etc. He's a great guy to have a beer with too. Keep up the good work! Facebook Page: S99Creations 2006 F250 Lariat Build Link to comment Share on other sites More sharing options...
UB6-IB9 Posted June 8, 2015 Author Report Share Posted June 8, 2015 Since i am still waiting to get my tahoe back from the mechanic this will be my next build(not for a bit yet) My 65 impala SS convertible Again sorry for pic quality its my iphone Link to comment Share on other sites More sharing options...
jcarter1885 Posted June 8, 2015 Report Share Posted June 8, 2015 Love that SS man Nav-TV Zen V Audio Interface AudioControl DM-608 (2) Stevens Audio Neo-Comp Full-Size Horns (4) Faital Pro 6PR160 6.5" AudioControl LC-6.1200 (1) Fi Neo 4.7 15" D2 in 3.74 Cubic Feet @ 27.70 Hz Ampere Audio AA3800.1 Odyssey ODP-AGM48 Battery (Starting) Odyssey ODX-AGM31 Battery (Trunk) Big 3 - 2\0 Welding Cable, KnuKonceptz Speaker Wire & 1/0 Power Cable, NVX RCAs, Second Skin (Speaker Tweaker Pads, Damplifier Pro Mat), Diode Dynamics LEDs Link to comment Share on other sites More sharing options...
