Strapping amps ohm question
csawatzky
please do a search for strapped amps. they are several long posts that will answer all of your questions
You would be wired to 1 ohm so if your amps are strapped they would each be seeing a .5 ohm load.
From what I have seen, once you strap an amp, the Ohm load increases, so if the he is using 2 amps, at 1 Ohm, 2 amps together would be 2 Ohm "Strapped".
This holds true for the Crossfire VR1000D as well as the Avionixx CXD2800M that I own. Unless the manufacturer of his amp has a different board set up.
-Frank
Wow lots of different answers... Not looking anywhere else because I've tried looking a long time...I know if I daisy chain each amp would see two ohms...I would like to be absolutely sure how many ohms I would be at strapped... Still not sure with all these different answers
  • Who's Online   1 Member, 0 Anonymous, 843 Guests (See full list)
