first question. Why did you post this in the music section? second. If you don't fully understand how caps work you might need to brush up on that. You cannot run just one of those, since their only rated at 2.8 volts per capacitor. Thirdly, capacitors store charge, they don't create voltage, so why would they turn your car's electrical system into a 16v system?
2007 Ford F-150 Reg. Cab. Flareside
250 Mechman Alternator
Sky High Car Audio Big 3
XS Power D3400
Rockford Fosgate 1/0 amp kit
Rockford Fosgate T1500-1bdcp
Rockford Fosgate T400-4
DC Audio Lvl 4 12"
Rockford Fosgate Punch 6.5" component
Rockford Fosgate Punch 6x8
Pioneer AVH-P2300DVD
SMD Volt Meter
Can't have music without power right? My bad I'll delete it and post it somewhere else. I thought running power in series increases voltage and in parallel voltage stays the same,
yea this should go in electrcal systems and components. and you are right in your thinking but wrong in your application. capacitors/batteries in series add voltage and in parallel add capacity but remain at same potential. But putting a capacitor in line to your amp is going to blow it up literally since it is only rated for 2.85 volts. you would need a working voltage of your alternator charging voltage to be usable. this is accomplished by adding 5-6 capacitors together to achieve a working voltage of 14.25-17.1volts if using 5-6 caps in series.
BMW M340 xDrive
Best Scores out of a trunk
154+ windows down, 155+ kick
So I can put 6 in parallel 500f putting it around 16 volts and that wouldn't cause any issues with the rest of the components in the electrical system?
no, you need to put 6 in series. and if you charged around 16v it may or may not cause harm to other parts of the vehicles electrical.
So the battery/amp just charges the capacitor to whatever it can
the amp doesnt charge anything.
the alternator is the first and highest source of potential. this will charge capacitors and battery.
I highly suggest not touching super caps until you have a very good understanding of them. You seem to have very little knowledge of electrical in general which can cause issues small to large and possibly even burning the car down. Read the supercap thread on here and also read everything electrical related so you can get a better understanding of how the electrical system works.
BMW M340 xDrive
