Willydsm Posted August 25, 2015 Report Share Posted August 25, 2015 Hello , new to the forum here, decided to come to the best for some help. Need some box specs and possible design help, 2-10 ab xfl 1044 subs on a 120.1 ab amp , trying to get a box built for an 02 mustang gt , my friend is a carpenter , and i have built boxes , but this is seeming quite difficult with the room i am givien Also should i build the box to face out back seat or sub towards trunk? Im looking for spl, any help would be very much appreciated, thank you Link to comment Share on other sites More sharing options...
Willydsm Posted August 26, 2015 Author Report Share Posted August 26, 2015 Anybody? Link to comment Share on other sites More sharing options...
yurvalentine Posted August 26, 2015 Report Share Posted August 26, 2015 Forward facing sealed off seems to do okay? For a Mustang that is....you're screwed on SPL regardless, just a heads up Link to comment Share on other sites More sharing options...
Joe X Posted August 26, 2015 Report Share Posted August 26, 2015 Here is a suggestion, need to verify the suggested dimensions will work, power: to subs rated, amp subsonic filter to 28Hz, minimum port clearance 4 1/4", figure is just an assembly guide, bracing is 1" wooden dowel rods: NOTE: If building outside you need to build a cardboard dummy box to test fit in it's way inside. Link to comment Share on other sites More sharing options...
Joe X Posted August 26, 2015 Report Share Posted August 26, 2015 If you can measure your trunk and build a cardboard box to see what can go through the trunk opening, maybe the above could be optimized a little. Link to comment Share on other sites More sharing options...
Willydsm Posted August 28, 2015 Author Report Share Posted August 28, 2015 Awesome thank you i will make a mock up tomorrow, i can build it but not to good with geometry, thank you again Link to comment Share on other sites More sharing options...
Willydsm Posted August 28, 2015 Author Report Share Posted August 28, 2015 Also subs are 1000rms a piece and amp is rated @2200 watts rms , also much won't fit through trunk if i go through back seat i can get 12" high 32" wide and up to 32" deep Link to comment Share on other sites More sharing options...
Willydsm Posted August 28, 2015 Author Report Share Posted August 28, 2015 Specs on subs Imp (Ohm) 2x4 Rdc (ohm) 1.7 Levc mH 2.194 Fo Hz 32.4 Sd msqM 33.01 BL TM 13.991 Qms 3.628 Qes 0.447 Qts 0.398 n% 0.478 SPL dB 87.6 Vas L 17.6 Cms uM/N 109 Mms g 229.2 VC Inch 3 Mgnt oz 220 Xmax ±MM 19 RMS 1000W MAX 2000W F.Range Hz <300 Mounting Depth MM 181 Inch 7.13 Link to comment Share on other sites More sharing options...
Joe X Posted August 28, 2015 Report Share Posted August 28, 2015 Ok what do you listen? Link to comment Share on other sites More sharing options...
Willydsm Posted August 28, 2015 Author Report Share Posted August 28, 2015 Top 40, rap, rock , little of everything, i love low notes, feels better when my subs do the breathing for me Link to comment Share on other sites More sharing options...
