d-nice88 Posted August 26, 2015 Report Share Posted August 26, 2015 So i had a box designed for 2 dc lvl 4 15's for my buick and I made the box and purchased fi bl 15's insted. Dont think the box sounds so good is there anyway I can get another design? 16h 28w 33d? Maybe some aero.ports would work ? Link to comment Share on other sites More sharing options...
d-nice88 Posted August 28, 2015 Author Report Share Posted August 28, 2015 Anyone ? Link to comment Share on other sites More sharing options...
d-nice88 Posted August 28, 2015 Author Report Share Posted August 28, 2015 Guess not :/ Link to comment Share on other sites More sharing options...
Triticum Agricolam Posted August 28, 2015 Report Share Posted August 28, 2015 More info about your setup would be handy. What kind of vehicle is it, what amp are you using, what are your goals for the system, what kind of music do you listen to? Your space is kinda small for two 15"s. "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds: Link to comment Share on other sites More sharing options...
Joe X Posted August 28, 2015 Report Share Posted August 28, 2015 d-nice88 your subs are not stock ones as you chose the SPL option, one would need to see parameters for them before deciding what enclosure to make, not really surprised it doesn't sound too good SPL oriented subs on a rather small enclosure. Link to comment Share on other sites More sharing options...
d-nice88 Posted August 28, 2015 Author Report Share Posted August 28, 2015 Gimmie a sec fellas ill find out. Also when I spome with someone at fi they said the spl option can still be used for daily music. It was 4-5 years ago it only really meant for burp use only Link to comment Share on other sites More sharing options...
d-nice88 Posted August 28, 2015 Author Report Share Posted August 28, 2015 DUAL 1 | DUAL 2 Fs: 33.6 Hz | 33.6 Hz Re: 0.7 Ohms/coil | 1.4 Ohms/coil Qms: 5.21 | 5.21 Qes: .28 | .28 Qts: .27 | .27 Mms: 261g | 261g Cms: 0.86mm/N | 0.86mm/N Sd: 810cm^2 | 810cm^2 Vas: 78.9 l | 78.9 l Spl: 91.8dB 1W/1m | 91.8dB 1W/1m Bl: 16.6 N/A | 22.7 N/A Xmax: 18mm | 18mm Rms: 1500W * | 1500W * Sealed box: N/A cuft | N/A cuft Ported box: 3-5cuft | 3-5cuft Sub OD: 15.625 | 15.625 Cut ID: 14.125 | 14.125 Mounting depth: 8.250 * | 8.250 * Displacement: 0.21cuft * | 0.21cuft Link to comment Share on other sites More sharing options...
Broke_Audio_Addict Posted August 28, 2015 Report Share Posted August 28, 2015 Are those the specs for the spl coil option? That being said a lot of people's definition of "music" is a clipped 30 hz sine wave with some 80 IQ knuckle head grunting about committing crimes and his genitals. Link to comment Share on other sites More sharing options...
d-nice88 Posted August 28, 2015 Author Report Share Posted August 28, 2015 2 fi bl 15's dual 1 ohm with cooling, flatwind coil, and spl option. Amp is hifonics atlas 6k (3000 watts rms at 1 ohm) 2 xs power d3400 Link to comment Share on other sites More sharing options...
Joe X Posted August 28, 2015 Report Share Posted August 28, 2015 Those parameters are for the stock BLs Link to comment Share on other sites More sharing options...
