Deeznutz Posted August 29, 2015 Report Share Posted August 29, 2015 So I've using this product since owning the Bimmer. Before that my S-10 had glass headlights so I had no need to use this product. Cost is $9.60 at Walmart. Some kits can run up to $30. Save your $$$. As you can see the truck really needed them. First the compound to remove the oxidation. You can use a 1500rpm pad and drill. I went old school and used elbow grease. I kept rubbing with repeated compound until the oxidation no longer appeared on the towel. It took a few minutes. If you're going to use your fingers and firm pressure, as the towel begins to squeak apply more compound use your other hand. Your fingers will get fatigued after a few minutes. Pretty much done. Fingers are killing me. The box said "If the oxidation clears, move to step 3 and apply the base and clear coats". Instead I used the pads. I used each progressive scuff pad for 2 minutes with lots of lube in a cross hatch pattern. Attacking the same direction from the left then the right, switching hands and position. (The instructions called for 1 min. per pad). After 8 min. of scuffing. I applied the base coat and dried with a hair dryer. Then applied the clear coat to prevent yellowing. Took a bit to get done, but much better than before! Good as new for now. This saves me $90.00 for after market head light replacements for at least a year. From what I've seen, lens restoration only lasts about 12-18 months, than the plastic begins to oxidize again. It's a natural process. The kit has enough base and clear for 2 cars. I put each wipe in a sandwich bag to protect them. Put the kit in an air conditioned room and the base/clear can be reused again next year. That's what I did.... The Bimmer and the Jimmy- same kit, 1 year apart! Hope this helps someone. Save your $$ man! -Frank Link to comment Share on other sites More sharing options...
audiolamb6 Posted August 29, 2015 Report Share Posted August 29, 2015 i may have to give this a try thanx for the write up Link to comment Share on other sites More sharing options...
79 cutty Posted September 9, 2015 Report Share Posted September 9, 2015 Turned out decent, but honestly, save your cash....toothpaste does the job as good or better. Make sure it is the paste though, not a gel Firm believer in letting my cars do my talking! You can't rush quality, it doesn't happen overnight. Quality takes time and dedication, but the end results more than pay for it. "Black Pearl" Build Thread http://www.stevemeadedesigns.com/board/topic/67183-1985-buick-regal-limited-build-log/page-1 Link to comment Share on other sites More sharing options...
Jessica Posted September 9, 2015 Report Share Posted September 9, 2015 have you tried using "deep woods off"? with deet Rest in peace, walled 87 accord build log 03' Corolla build with AA Mayhem inside. My super random youtube channel and terrible camera work. Wiring comparison by CaptainzPlanetz Wire and fuse guide by Guest SyKo13 Link to comment Share on other sites More sharing options...
Borris The Blade Posted September 9, 2015 Report Share Posted September 9, 2015 have you tried using "deep woods off"? with deet That surprisingly works. I bought the meguiars kit and my wife seen and said watch this. She grabbed the Off and did a quick scrub with it and cleared it up pretty well. It's like rubbing your wiener up against a sheep. Link to comment Share on other sites More sharing options...
Deeznutz Posted September 16, 2015 Author Report Share Posted September 16, 2015 Yes, there are cheaper products that work, but these plastic headlight covers have a protective film on them that washes away over time. What you guys are really doing is the same as what compound paste does for automotive paint. There is no real protection after you scuff it with Deet or toothpaste. It's only a bandaid. Thus must kits come with a base and clear- which will eventually wash off as well. Everything has a life span. -Frank Link to comment Share on other sites More sharing options...
Polar Posted September 16, 2015 Report Share Posted September 16, 2015 looks like new! 2000 Ford Ranger Sport Ext Digital Designs DD915J 4.91 net birch box, inch port @ 33hz FSD FZ2600 FSD FZ100.4 Pioneer DEH80PRS PRV Audio 6MB200-4 6-1/2" Midbass Woofers Tymphany BC25SC08-04 1" Silk Dome Neodymium Tweeters with Waveguide Link to comment Share on other sites More sharing options...
