When i am listing to music and the bass drops heavy sometimes the subs stop... then i change the song and they come back on.. this is while im driving
Maybe i have a loose wire somewhere?
any ideas
Christopher
My vehicle
http://www.stevemeadedesigns.com/board/garage/vehicle/3100-buick-rainier/?tab=images
2005 Buick Rainier CXL - Bose Premium & OnStar
Subs - P1 x 2 Ported Box
Amp - Kentwood Excelon X500-1 Mono block D amp - 1000W rms 1- Ohm 500W rms 2 ohm
Deck Kentwood BD362U
Mids / Highs - Bose Premium Sound System
YouTube Video of system
Play the same song 2-3 volume levels below where you know the subs are known to cut off. (if it's known to clip at volume 32, drop down to 29, than up to 30, than 31). See if it still does it. I'm guessing it might not. Check your amp gains. Dropping some low notes taxes the amplifier the most and your amp is letting you know by going into protection for a second. Changing the song gives your amp a mini vacation from the torture.
-Frank
Deck Settings:
Sub Woofer Level - +15
bass level - 0
mid level - 0
treb level - +8
bass boost level 3
loudness level 2
subwoofer set - on
LPF subwoofer - 85 hz - recommended by rockford fosgate
subwoofer phase - normal
HPF - through
volume offset - 0
AMP Settings
Bass boost level db - 1 - 18 - (1)
LPF - Between 100 - 70 - (80)
Input Sensitivity - min 5 - 0.2 Max - (2)
Christopher
My vehicle
I had that problem before on an alpine amp I had in the past. It was rated for 2 OHM and when I hooked it up at a 1 OHM load, it would cut out at about 40% volume.
Looks like you have the Kenwood X500-1 amplifier that is a 2 OHM amp. How did you wire your subs?
many things could cause this:
  • it could be electrical when the bass hit it draw so much that the voltage drop below the amps voltage range.
  • speaker wire might be touching from the vibration (also check the terminals make sure its intact)
  • check your ground connections
  • check your ohms readings, make sure its at where you want it to be in the amp recommend ohms range.
  • some amps are sensitive to the settings
4 Fi Q 12s In A Prius on 4 Crescendo BC2000D?! :WTFBubble: That's Absurd (!!!UNDER CONSTRUCTION!!!) go follow http://www.stevemeadedesigns.com/board/topic/190658-the-first-prius-with-4-12s/
c42977d4-a28f-47b5-a02f-49dbb8697b2d_zps
I figured it out it was a bad ground. The bolt it was grounded to was not really a ground So I found bare metal and sanded it down even more then I sodared the thermal to the ground wire and now it freken pounds hard with no interruptions
Christopher
My vehicle
  • Who's Online   1 Member, 0 Anonymous, 1663 Guests (See full list)
