jmkanek Posted September 18, 2015 Report Share Posted September 18, 2015 (edited) Just wondering if the XS vcms will work with an internally regulated js ultimate alts 300a 6 phase hairpin alternator. The alt has a 4 pin oval. Wanting to run 16 volt system with this alt Thanks. Edited September 19, 2015 by jmkanek Quote 1995 Acura integra Link to comment Share on other sites More sharing options...
Pioneerchuck Posted September 22, 2015 Report Share Posted September 22, 2015 Just wondering if the XS vcms will work with an internally regulated js ultimate alts 300a 6 phase hairpin alternator. The alt has a 4 pin oval. Wanting to run 16 volt system with this alt Thanks. If you're hoping to run a dedicated 16v system then you will need a 16v battery bank, step down module for your vehicles electrical system, and you'll need to have the alt rebuilt to handle a 16v output. Quote Link to comment Share on other sites More sharing options...
jmkanek Posted September 23, 2015 Author Report Share Posted September 23, 2015 Just wondering if the XS vcms will work with an internally regulated js ultimate alts 300a 6 phase hairpin alternator. The alt has a 4 pin oval. Wanting to run 16 volt system with this alt Thanks. If you're hoping to run a dedicated 16v system then you will need a 16v battery bank, step down module for your vehicles electrical system, and you'll need to have the alt rebuilt to handle a 16v output. I have ran 16volt in a past build. the xs power vcm supposed to work with internal regulated alternators to alter charging voltage, but i have read somewhere about them only being able to adjust 6 phase hairpin alternators up in the 15 volts range, but don't see why i couldn't adjust to the normal 19.0-19.2 for the 16 volt bank. Just wantiing to verify with someone at XS before i order the VCM. Quote 1995 Acura integra Link to comment Share on other sites More sharing options...
