bman8891 Posted November 24, 2015 Report Share Posted November 24, 2015 Ive got two xs d6500's under the hood on a stock 130 amp alternator just installed them brand new. The truck fully charged at 2000 rpm is 13.9 and at idle is 13.8. The truck off is like 12.8. Most vehicles I see are around 14.4 charged. Is it just because I have a stock alt? Link to comment Share on other sites More sharing options...
Ninja_v1.0 Posted November 24, 2015 Report Share Posted November 24, 2015 fuck it Link to comment Share on other sites More sharing options...
andru Posted November 24, 2015 Report Share Posted November 24, 2015 missing link audio make a module to safely step up your voltage Link to comment Share on other sites More sharing options...
Miguels Posted November 24, 2015 Report Share Posted November 24, 2015 I wouldn't worry too much. There are cons to charging at a higher voltage and if you're not competing there is no reason to charge higher. You won't even hear the difference to be honest. 13.9 is good if you ask me my logshttp://www.stevemead...-my-new-set-up/my blow through loghttp://www.stevemead...future-updates/ 96 ss http://www.stevemeadedesigns.com/board/topic/164094-96-impala-ss-build/ Link to comment Share on other sites More sharing options...
never knows best Posted November 24, 2015 Report Share Posted November 24, 2015 i wouldnt be too worried about it. if you havent already, do the big three. also cleaning up connections might get you an extra tenth or two. Link to comment Share on other sites More sharing options...
Massivespl Posted November 24, 2015 Report Share Posted November 24, 2015 Ive got two xs d6500's under the hood on a stock 130 amp alternator just installed them brand new. The truck fully charged at 2000 rpm is 13.9 and at idle is 13.8. The truck off is like 12.8. Most vehicles I see are around 14.4 charged. Is it just because I have a stock alt? what did U charge at before adding extra battery's? If u charged 14.4v then I bet the battery's just arnt fully charged. Once u get them fully charged u should charge higher again. c-pillar flat wall 157.11db on music 2 crossfire 8k 4 NSV3 18s 4 crescendo 10s 4 Rockford pro 6.5s Quad excessive amperage 350alts 4 juicebox 3100s Link to comment Share on other sites More sharing options...
Miguels Posted November 24, 2015 Report Share Posted November 24, 2015 There is no need for a big 3.. People think the big 3 is a magical thing but for a stock alt the stock wire is sufficient maybe add a ground or 2since stock ground can be shitty but changing the power wire aint going to do anything for the cause. Most the draw is going to happen on the runs to the batteries. The alt will only supply 130a at max so putting 1/0 wire won't do a thing. People who notice a difference are people who have neglected the stock wiring and needed it changed not upgraded. Upgraded wire will suffice with an upgraded alternator my logshttp://www.stevemead...-my-new-set-up/my blow through loghttp://www.stevemead...future-updates/ 96 ss http://www.stevemeadedesigns.com/board/topic/164094-96-impala-ss-build/ Link to comment Share on other sites More sharing options...
never knows best Posted November 24, 2015 Report Share Posted November 24, 2015 There is no need for a big 3.. People think the big 3 is a magical thing but for a stock alt the stock wire is sufficient maybe add a ground or 2since stock ground can be shitty but changing the power wire aint going to do anything for the cause. Most the draw is going to happen on the runs to the batteries. The alt will only supply 130a at max so putting 1/0 wire won't do a thing. People who notice a difference are people who have neglected the stock wiring and needed it changed not upgraded. Upgraded wire will suffice with an upgraded alternator true, i was referring more to the grounds than power.... but while your doing it why not do the power also??? nobody said it had to be 1/0 if it isnt necessary- i would lean more to cleaning up connections first and relocating stock ground might help. Link to comment Share on other sites More sharing options...
Bump4life Posted November 24, 2015 Report Share Posted November 24, 2015 The big 3 can never hurt. depending on stock wiring size they dont engineer the wire to be used for constant max draw all the time since they didnt plan on a huge stereo being installed. Wires do heat up. to get most out of stock charging system and highest voltage (lowest voltage drop) the big in OFC should always be completed Buyer/Seller Feedback Thread: http://www.stevemead...5015-bump4life/ MB C220 153 Trunk Car Build Log: http://www.stevemead...d/#entry1840136 MB C280 Ipad Dash SQ Build Log: http://www.stevemeadedesigns.com/board/topic/194484-bump4lifes-new-benz-tony-c-relay-kit-pictures-ce-electric-audison-front-stage-installed/ My SPL Log: http://www.stevemead...__fromsearch__1 BMW M340 xDrive Stock, for now. Corner Load 10" maybe soon. But does 10s in the 1/4... Best Scores out of a trunk 153.0 sealed legal full tilt clamped 5524 @ 42 hz 154+ windows down, 155+ kick Link to comment Share on other sites More sharing options...
hdorre Posted November 24, 2015 Report Share Posted November 24, 2015 i dont get the infatuation with having such a high charging voltage, especially when you dont have the amperage to hold it. 13.9 is fine. On 5/8/2011 at 7:38 PM, Kranny said: On 5/8/2011 at 7:35 PM, 'Maxim' said: It hurts me inside when I read stuff like this and remember you're 15 LMFAO so true Mitsubishi 3000GT (Old Build) Headunit: Pioneer 80PRS Frontstage: (2) McLaren Audio MLT-2 Tweeters & (4) PRV Audio MR Series Neo 6.5" Mids Substage: 4 15" Hybrid Subs - Tantric Motors & Sundown Softies Amps: Banda 2.4D Amp (Tweets), American Bass VFL 350.4 (Mids), and (2) Ampere 3800s Electrical :Singer 260A Alt & JY Power Lithium 2005 Chevy Colorado Ext Cab Headunit: Pioneer 80PRS Frontstage: 4 PRV 700Ti Tweets & 6 10" Delta Mids on 3000wrms Substage: 6 Fi BTL 18s in a 4th Order Walkthrough on 3 Wolfram 4500s Electrical: Singer "390" and JY Power My Official Feedback Thread Link to comment Share on other sites More sharing options...
