ModernDayHero07 Posted February 10, 2016 Report Share Posted February 10, 2016 I have a friend who messaged me a problem they were having. I am not sure what is going on, but my guess is that something inside the amp is not working and/or broken and that he will at least need a new amp. I have no idea if I am right, so I come to you guys for your thoughts. Here is the message he sent me:" I've been having a problem with my stock stereo for a long time, maybe you have an idea of what it could be. I have a 2004 Tahoe with a bose amp and the stock head unit. I've been having loud static that sounds like it is coming from the amp. I put my ear down by where the amp is and can hear the static. Sometimes the volume completely cuts out like the amp turns off. Do you have any idea what this could be? " Link to comment Share on other sites More sharing options...
ShadeTreeMechanic Posted February 10, 2016 Report Share Posted February 10, 2016 Sounds like amp is on its last leg. I have heard the transistors in big power supplies when they are maxed / overloaded. It almost sounds like they are screaming or singing. High pitched but not very loud. 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon) Link to comment Share on other sites More sharing options...
