Ford f150 2010 needs just a little more
Get a tuner or a supercharger. That's pretty much the only other things you can do to it besides ripping out the stock Ford motor and putting in a racing crate motor in it.
Vehicle: 2013 Ford F-150 STX SuperCab 5.0L V8 4x4
BIG 3: Knukonceptz Kolossus Fleks 0 Gauge OFC Power Amp Kit
Headunit: Stock (Leaving factory look)
Speakers: Stock
Subwoofer: Incriminator Audio Lethal Injection 10" D2 wired down to 1 ohm
Enclosure: ~1.5 cubic feet tuned to ~34 Hz (Port Area ~24 inches)
Amplifier(s): Sundown Audio SAE1000.1D
Amp Power Kit: Knukonceptz Complete 4 Gauge OFC Amplifier Installation Kit
It's a truck if your looking for speed should of bought a Raptor . F150's are tanks also the 5.0 is a awesome motor if you wanna upgrade .I'd stay away from anything turbo don't wanna start any trouble but heat and oil don't mix after you start putting miles on them
2022 Ford Maverick on 22’s        Skar SK1500.1 on 4 Skar VD-8’s        Mids Sundown Super tweeters, Skar TX 6.5 components on Skar SKM400.4                                                 LC2 for audio control  , XS Power D680 XS Series Extra Battery
It's a truck if your looking for speed should of bought a Raptor . F150's are tanks also the 5.0 is a awesome motor if you wanna upgrade .I'd stay away from anything turbo don't wanna start any trouble but heat and oil don't mix after you start putting miles on them. You could look in to getting a chip but it's still a big heavy truck.sorry double post I'm a dumbass . Also I own a super crew 2010 and love it.
U can't just slap a super charger on it . U will shoot a rod out the side of the block . Super charges mean bigger injectors, fuel pump , pcm relearn also stronger internal parts unless u go to like 3lbs of boost but then it's not worth it. I don't know much about chips but at work when people come in with problems the first thing I recommend is removing it but some might be ok . If you get one always go name brand I think bullydog makes good products I'm sure there is more just do a lot of research
If you wanna spend money find a raptor in a junkyard get the motor and pcm . It should bolt up to that trans I think.
no matter what u still got a badass truck im a ford guy for life.
  • Who's Online   0 Members, 0 Anonymous, 932 Guests (See full list)
