Kyle13130 Posted February 25, 2016 Report Share Posted February 25, 2016 http://imgur.com/a/1KDsc 1.5" x 1.5" Thickness MDF Is the bracing blocking the aero port out too much? I was thinking about maybe removing the center vertical bar or the horizontal one, maybe even both. Link to comment Share on other sites More sharing options...
Kyle13130 Posted February 25, 2016 Author Report Share Posted February 25, 2016 It's a 57 pound woofer so it needs as much vertical support as it can get. Any thoughts? I feel like it would just disrupt the airflow too much with the vertical support where it is and I should just keep the horizontal? Link to comment Share on other sites More sharing options...
reedal Posted February 25, 2016 Report Share Posted February 25, 2016 That should be ok, and not cause problems. You could also do this The bracing, not the slot port SMD Tool Map https://www.stevemeadedesigns.com/board/topic/193176-smd-tool-map-new-november-2014/ Build log https://www.stevemeadedesigns.com/board/topic/197217-reeds-03-tahoe-hat-sqaq-singer-xs-shca-cockbox-80prs/?page=32 Link to comment Share on other sites More sharing options...
Triticum Agricolam Posted February 25, 2016 Report Share Posted February 25, 2016 The way you have the bracing in the SketchUp photo should be fine. The way Reedal did it is a little better though. "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds: Link to comment Share on other sites More sharing options...
