d-nice88 Posted March 20, 2016 Report Share Posted March 20, 2016 So guys im trying to get a little more info on these. Ive tried googling and havent really come up on some good detailed info on these. Would using these be beneficial in a 4k plus system ? Right now i just have a nvx 10 farad cap/distro block wondering if getting some of these in a lil bank would be great or not. Link to comment Share on other sites More sharing options...
audiofanaticz Posted March 20, 2016 Report Share Posted March 20, 2016 6 supercaps making 1 bank would walk all over that nvx 10 fared capacitor. That being said you need 6 supercaps wired in series to make 1 bank. You want the 2.7volt 3000 fared models. So when you wire them in series, the voltage increases but the fared rating decreases. So you end up with a 16.2volt 500 fared bank of capacitors after you series 6 together. The 16.2voltage doesnt mean that your car will run at 16.2volts. It just means that is their max charge without damage. So if your alternator is charging at 14.8volts you will only charge the capacitors to 14.8volts. If your vehicle charged at 18volts you would need to series 7 caps together etc. You should really use load balancing circuits on them, many spl competitors dont. Im sure Im forgetting a bunch, so someone else can fill in what I forgot. These are pictures of what you are wanting below: These black Maxwells are a really old style. These are also Maxwells iirc but slightly newer than the black ones. and these Maxwells which is the newest style iirc. Then you have Ioxus Also XS Power has some, but iirc they are made by Ioxus and relabled for XS Power. But you can buy these in a premade bank of 6 from XS Power. Link to comment Share on other sites More sharing options...
audiofanaticz Posted March 20, 2016 Report Share Posted March 20, 2016 Now Im second guessing myself, I think the blue ones that say Boostcap maybe the newer models than the blue ones that say maxwell on them cant really remember. Anyways here are a couple pics of the XS Power capacitor that is all made ready to hook up. These seem to be the only 2 pics I could quickly find of it. Here is a picture of Andrews truck (Black Nasty). He only runs caps, no batteries except for a starting battery iirc. He does 160s on music. You can also see the load balancers that I mentioned in my other post on top of his caps. Probably one of the nicest capacitor installs that Ive seen. Link to comment Share on other sites More sharing options...
SnowDrifter Posted March 20, 2016 Report Share Posted March 20, 2016 You should really use load balancing circuits on them, many spl competitors dont. You can either use 1% tolerance 100 ohm resistors wired along the positive and negative of each individual cap, or you can go for an active balancing system like this: www.electriccarpartscompany.com/6A-6000mA-Continuous-BalancingbrBattery-AH-50-3000br2-Unlimited-Cell-CountbrLithium-bPlease-Specify-Chemistrybbror-Lead-Acid-AGM-Gel-SiliconbrCharge-Discharge-StoragebrBattery-Voltage-Amperage-BalancersEqualizers_p_320.html ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444 Link to comment Share on other sites More sharing options...
audiofanaticz Posted March 20, 2016 Report Share Posted March 20, 2016 You should really use load balancing circuits on them, many spl competitors dont. You can either use 1% tolerance 100 ohm resistors wired along the positive and negative of each individual cap, or you can go for an active balancing system like this: www.electriccarpartscompany.com/6A-6000mA-Continuous-BalancingbrBattery-AH-50-3000br2-Unlimited-Cell-CountbrLithium-bPlease-Specify-Chemistrybbror-Lead-Acid-AGM-Gel-SiliconbrCharge-Discharge-StoragebrBattery-Voltage-Amperage-BalancersEqualizers_p_320.html These are what Andrew is using it looks like as well http://www.ebay.com/itm/INTEGRATION-KIT-for-Maxwell-BoostCap-Capacitors-BCAP3000-/252248970290?hash=item3abb35d432:g:VnAAAOSwX~dWlgWh Link to comment Share on other sites More sharing options...
Miguels Posted March 20, 2016 Report Share Posted March 20, 2016 that xs power cap look bad ass my logshttp://www.stevemead...-my-new-set-up/my blow through loghttp://www.stevemead...future-updates/ 96 ss http://www.stevemeadedesigns.com/board/topic/164094-96-impala-ss-build/ Link to comment Share on other sites More sharing options...
Broke_Audio_Addict Posted March 20, 2016 Report Share Posted March 20, 2016 that xs power cap look bad ass X2, where the hell do I buy one? I just checked around and don't see them for sale anywhere. That being said a lot of people's definition of "music" is a clipped 30 hz sine wave with some 80 IQ knuckle head grunting about committing crimes and his genitals. Link to comment Share on other sites More sharing options...
d-nice88 Posted March 20, 2016 Author Report Share Posted March 20, 2016 Sweet so ill do that audio fanatic ill check the price on the xs power one and get that to match my d3400's in the back. I would love to keep strong electrical always so im trying to find the best easiest cost effective way to do that since in my vehicle i cant run dual alts. Im in the process of saving up for a hair pin mechman maybe a 320 amp or hit up mike singer and get a qoute from him. My 250 mechman is still doing good but i always wana leave room to go bigger Link to comment Share on other sites More sharing options...
d-nice88 Posted March 20, 2016 Author Report Share Posted March 20, 2016 http://m.ebay.com/itm/12V-super-capacitor-module-6x-350-farad-caps-300A-engine-starting-car-audio-/111883927289?nav=SEARCH Is that like what your talking about or close to it ? Link to comment Share on other sites More sharing options...
SnowDrifter Posted March 20, 2016 Report Share Posted March 20, 2016 Yes but those are the baby versions. About 1/8 the size of the ones we reference ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444 Link to comment Share on other sites More sharing options...
